TinyGPS++ probema connessione seriale
Dopo aver rinunciato vista la mia scarsissssssssssima abilità di programmatore ad estrarre la string NMEA dal mio modulo sim808..sto provando a utilizzare la library TintGPS++..CON ALTRETTANTO IMBARAZZANTI RISULTATI..
Ho cambiato il codice di esempio
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
   This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
  ss.begin(GPSBaud);
  Serial.println(F("DeviceExample.ino"));
  Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
  Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart"));
  // This sketch displays information every time a new sentence is correctly encoded.
  while (ss.available() > 0)
    if (gps.encode(ss.read()))
      displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void displayInfo()
  Serial.print(F("Location: "));
  if (gps.location.isValid())
    Serial.print(gps.location.lat(), 6);
    Serial.print(F(","));
    Serial.print(gps.location.lng(), 6);
    Serial.print(F("INVALID"));
  Serial.print(F("  Date/Time: "));
  if (gps.date.isValid())
    Serial.print(gps.date.month());
    Serial.print(F("/"));
    Serial.print(gps.date.day());
    Serial.print(gps.date.year());
  Serial.print(F(" "));
  if (gps.time.isValid())
    if (gps.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps.time.hour());
    Serial.print(F(":"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps.time.minute());
    if (gps.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps.time.second());
    Serial.print(F("."));
    if (gps.time.centisecond() < 10) Serial.print(F("0"));
    Serial.print(gps.time.centisecond());
Adattandolo al mio Esp32 dove uso un Seriale hardware in questo modo
#define RXD2 16
#define TXD2 17
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
 Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
  while (Serial2.available() > 0)
    if (gps.encode(Serial2.read()))
      displayInfo();
    while(true);
void displayInfo()
Ma a quanto pare devo aver sbagliato qualcosa perchè mi da come risultato "No GPS detected: check wiring." Dove ho sbagliato? Devo aggiustare qualcosa all'interno della libreria?
Grazie mille
