TinySine WiFi Shield problems
Hello,
I have recently bought a TinySine WifiBee shield, but I can’t really seem to get it to work.
Well, I manage to get it up and running, and I manage to Telnet to it and read its output which means it
is connected to the WiFi.
BUT when i try to use one of the premade programs in “Example → Wifi”, it says “WiFi shield not present”.
As far as I have googled and searched, I’ve concluded that the “WiFi.h” library is not intended for the TinySine shield.
But, if that is the case, I can not find any library that supports the shield.
I have read that other people here has similar problems with the shield, but I have yet to find a thread where they found an answer.
Is there anyone here that has any info regarding this problem?
I really want to make use of this shield, and so far I can’t see any…
Thank you for all info!
The "WiFibee" is not a clone of the Arduino WiFi Shield and is apparently not compatible with the WiFi library. You will need to find a library and examples specific to the WiFibee.
Did you Gargle TinySine WifiBee arduino
[http://www.tinyosshop.com/datasheet/Tinysine%20WIFI%20shield.pdf](http://"http://www.tinyosshop.com/datasheet/Tinysine WIFI shield.pdf")
Looks like a lot of work to me.
Tom.... :slight_smile:
