TinyWireS : is there more than one version ?????
Hi folks,
A while ago, I did a design that used an ATTiny85 and communication over I2C. It worked fine !
time has passed, new computer, so I have re-installed my softwares, including Arduino. Downloaded TinyWireS.
Re-opened my old sketch, but it would not compile anymore....
Old one had the following:
Wire.begin(8);                // join i2c bus with address #8
Wire.onRequest(requestEvent); // register event
When I compiled, the error message said that onRequest does not exist !!!
Opened the example that came with the library. the example was rather using this:
if (TinyWireS.available()){           // got I2C input!
byteRcvd = TinyWireS.receive();
It's not the first time that I have that issue with TinyWireS
Am I the only to have experienced that situation ?????
I wonder if the trick that solved the problem the first time would work again.
Been a while for that one too.... not sure which version is which any more....
just curious if it's me or what ?!
I confirm: TinyWireS exist in 2 versions
One that uses "onRequest" and one that does not.
Just spent a couple of hours searching/renaming/trying different libraries named "TinyWireS"
