TinyWireS - Slave Code on ATTiny85 - Request Method Messed up from Interrups?
I've built a frequency/counting device with an ATTiny85.. It seems to be working, but after a handful of reads from the Master device, the ATTiny start to send junk.. I think this is because the byte ordering is getting mixed up...
SendCount is initialized to 0 in the Setup() Method.
Here's my Request method:
volatile unsigned long Data1;//this is the data from the frequency method
volatile byte SendCount;
volatile uint8_t sendByte;
void requestEvent()
  SendCount++; //increment this
  switch (SendCount)
    case 1:
      Data1 = TinyFrequencyCounter.GetHz();
      sendByte = Data1 & 0xFF;
    case 2:
      sendByte = Data1 >> 8;
    case 3:
      sendByte = Data1 >> 16;
    case 4:
      sendByte = Data1 >> 24;
      SendCount=0;
  TinyWireS.send(sendByte);
I've tried a few different ways to count frequency I am counting interrupts until I get a timer 1 overflow. it's accurate enough for my purpose at this point
ISR(PCINT_VECTOR)
  PulseCount++;
ISR(TIMER1_OVF_vect) //Core Build Options.H line:112 - change from 1 to 0
  //The timer have overflowed get the pulse count;
  GatePulseCount = PulseCount;
  PulseCount=0;
Are the ISRs affecting the Request Event? How can I fix this?
