I currently have an LCD connected to an Arduino that is suppose to turn on a pump when a button is pressed. I used a tip 120 transistor where the base is connected to pin 9, the collector is connected to an outside 9v battery and the pump is connected to the emitter. When I have everything connected, the pump is running even when I did not press the button yet. Can someone please help me solve this problem. Thank you.
