TIP3055 Vs MOSFET for LED Strobe
First off, a thank you to any who man answer! This is my first post here. Up until about 6 months ago, I had never been involved with micro controllers at all. I am mainly a Comms guy. I was tasked as part of a development team at work to built a smart battery charger for some of our aircraft emergency batteries, and let's say the rest is history!
So I have taken some of what I am learning and applied it to my "second job" of lighting for off road race trucks. I built a strobe controller that strobes 18 watt LED pods. I am wanting to expand it to controlling several LED bars that have around a 15A current draw when full on. for the pods, I have just been using TIP120's and they work great. No heat issues, etc. I was looking at the TIP3055 for the higher amp capacity but after reading some other posts here, I see the STP40NF10L MOSFET being recommended a lot for higher load projects.
My question is, will the STP40NF10L switch on and off fast enough for the strobe effect? I can't quite grasp the data sheet yet, although I have my face buried in a good book on the subject.
Any feedback/experience would be greatly appreciated.
Nick
Not so much the talkative bunch I suppose. :slight_smile:
In which case using a TIP3055 with a maximum current of 15A is not such a good idea. You should always aim to run transistors at 80% or less of the maximum rating.
Strobes are glacially slow in electronics terms so there is nothing that will not respond that fast.
Thanks man. I am watching the mailbox now for the MOSFET. For the smaller LED pods, I am just using the old TIP 120 since I had a bag full of them. In strobe mode, the LED isn't on long enough to care about the slight voltage drop.
Video of the effect that I came up with for the forward and rear LED pods:
Imgur
