Tips how to reduce RAM usage in my code?
Hey guys,
My program is sometimes getting stuck, as it uses way too much of the dynamic memory of my Arduino Uno. Sadly I don't know how to reduce that, I hope you can give me some tips or push me in the right direction :slight_smile:
This is what it says: Global variables use 2032 bytes (99%) of dynamic memory, leaving 16 bytes for local variables. Maximum is 2048 bytes.
My project has a potentiometer and 10 capacitive sensors, which I declared as global variables in the beginning. When you touch one of them, the Arduino plays a .wav song from an SD card module fitting the combination of the potentiometer (representing a decade) and the capacitive sensors (representing different regions.).
In order to do this, I need several libraries (which I think also use RAM, if I am correct.) and for example, the capacitive sensor library has to use long variables. I tried using int to save memory, but that did not work.
I have one big loop that does this all, but I am happy to learn how I could do this differently in a way that uses less memory.
Here is my code:
//for the SD card module:
#include "SD.h"
#define SD_ChipSelectPin 4
#include "TMRpcm.h"
#include "SPI.h"
TMRpcm tmrpcm;
//for the sensors:
#include <CapacitiveSensor.h>
char songname[ ] = "nothing";
CapacitiveSensor   cs_a4_a5 = CapacitiveSensor(A4, A5); //North America
CapacitiveSensor   cs_a4_a3 = CapacitiveSensor(A4, A3); //South America
CapacitiveSensor   cs_a4_a2 = CapacitiveSensor(A4, A2); //Europe
CapacitiveSensor   cs_a4_a1 = CapacitiveSensor(A4, A1); //Africa
CapacitiveSensor   cs_a4_2 = CapacitiveSensor(A4, 2);   //Middle East
CapacitiveSensor   cs_a4_3 = CapacitiveSensor(A4, 3);   //Russia
CapacitiveSensor   cs_a4_5 = CapacitiveSensor(A4, 5);   //India
CapacitiveSensor   cs_a4_6 = CapacitiveSensor(A4, 6);   //China
CapacitiveSensor   cs_a4_7 = CapacitiveSensor(A4, 7);   //Asia
CapacitiveSensor   cs_a4_8 = CapacitiveSensor(A4, 8);   //Oceania
//for the potentiometer:
int sensorValue = 0;
int decade = 0;
  // Music Output:
  tmrpcm.speakerPin = 9;
  if (!SD.begin(SD_ChipSelectPin)) {
    Serial.println("SD fail");
    return;
  tmrpcm.setVolume(6.5);
  // Capacitive Sensors:
  long sensor1 =  cs_a4_a5.capacitiveSensor(50); //variable for region 1
  long sensor2 =  cs_a4_a3.capacitiveSensor(50); //variable for region 2
  long sensor3 =  cs_a4_a2.capacitiveSensor(50); //variable for region 3
  long sensor4 =  cs_a4_a1.capacitiveSensor(50); //variable for region 4
  long sensor5 =  cs_a4_2.capacitiveSensor(50); //variable for region 5
  long sensor6 =  cs_a4_3.capacitiveSensor(50); //variable for region 6
  long sensor7 =  cs_a4_5.capacitiveSensor(50); //variable for region 7
  long sensor8 =  cs_a4_6.capacitiveSensor(50); //variable for region 8
  long sensor9 =  cs_a4_7.capacitiveSensor(50); //variable for region 9
  long sensor10 =  cs_a4_8.capacitiveSensor(50); //variable for region 10
  Serial.print("n:");
  Serial.print(sensor1);  // print sensor output
  Serial.print("\ts:");
  Serial.print(sensor2);  // print sensor output
  Serial.print("\te:");
  Serial.print(sensor3);  // print sensor output
  Serial.print("\ta:");
  Serial.print(sensor4);  // print sensor output
  Serial.print("\tm:");
  Serial.print(sensor5);  // print sensor output
  Serial.print("\tr:");
  Serial.print(sensor6);  // print sensor output
  Serial.print("\ti:");
  Serial.print(sensor7);  // print sensor output
  Serial.print("\tc:");
  Serial.print(sensor8);  // print sensor output
  Serial.print("\tz:");
  Serial.print(sensor9);  // print sensor output
  Serial.print("\to:");
  Serial.println(sensor10);  // print sensor output
  //potentiometer for decades
  int sensorValue = analogRead(A0); // read the input on analog pin 0:
  decade = map(sensorValue, 0, 1023, 10, 0);  // map it to the range of the analog out:
  Serial.print("sensor = "); // print the results to the Serial Monitor:
  Serial.print(sensorValue);
  Serial.print("\t decade = ");
  Serial.println(decade);
  if (sensor1 > 70) {
    sprintf(songname, "n%d.wav", decade);
    tmrpcm.play(songname);
    Serial.print("now playing you a song from North America from the decade ");
    Serial.print(decade);
    Serial.print(": ");
    Serial.println(songname);
    delay(300);
  if (sensor2 > 70) {
    sprintf(songname, "s%d.wav", decade);
    Serial.print("now playing you a song from South America from the decade");
    Serial.print(": ");
    delay(300);
    if (sensor3 > 70) {
    sprintf(songname, "e%d.wav", decade);
    Serial.print("now playing you a song from Europe from the decade");
    Serial.print(": ");
    delay(300);
  if (sensor4 > 70) {
    sprintf(songname, "a%d.wav", decade);
    Serial.print("now playing you a song from Africa from the decade");
    Serial.print(": ");
    delay(300);
  if (sensor5 > 70) {
    sprintf(songname, "m%d.wav", decade);
    Serial.print("now playing you a song from the Middle East from the decade");
    Serial.print(": ");
    delay(300);
  if (sensor6 > 70) {
    sprintf(songname, "r%d.wav", decade);
    Serial.print("now playing you a song from Russia from the decade");
    Serial.print(": ");
    delay(300);
  if (sensor7 > 70) {
    sprintf(songname, "i%d.wav", decade);
    Serial.print("now playing you a song from India from the decade");
    Serial.print(": ");
    delay(300);
  if (sensor8 > 70) {
    sprintf(songname, "c%d.wav", decade);
    Serial.print("now playing you a song from China from the decade");
    Serial.print(": ");
    delay(300);
  if (sensor9 > 70) {
    sprintf(songname, "z%d.wav", decade);
    Serial.print("now playing you a song from Asia from the decade");
    Serial.print(": ");
    delay(300);
  if (sensor10 > 70) {
    sprintf(songname, "o%d.wav", decade);
    Serial.print("now playing you a song from Australia or New Zealand from the decade");
    Serial.print(": ");
    delay(300);
Instead of the number 70 I had a global variable threshold before, I changed that and hoped it would save memory, but I think it did not help.
Thanks for any help! :sweat_smile:
You can start by storing strings in flash memory rather than RAM with macro F() or PSTR()
Example :
Serial.print(F("now playing you a song from Europe from the decade"));
sprintf_P(songname, PSTR("s%d.wav"), decade);
More info:
http://www.arduino.cc/playground/Learning/Memory
http://arduino.cc/playground/Main/Printf
Thank you so much, these 2 little hacks already helped a lot, it is working so much more smoothly now!
