Hi everybody,
I am working on a little project of mine. With the use of 4 sensors i control the speed of a fan.
If the first sensor see's something the fan will run on 25%. If the first en second senor see something the fan will run 50%. And so on.
To indicate the speed of the fan i use 4 leds. 1 led burning means 25%, 2 leds 50%.
Now the code i wrote works fine. Only i have the idea that it's written to long-winded.
I hope you guys can give me some advice.
//Robin Hengeveld , 2012 , Fan speed control with LED indication
const int L1 = 2, L2 = 3 , L3 = 4, L4 = 5; //LED pin declarations
const int S1 = 9, S2 = 10, S3 = 11, S4 = 12; // Sensor pin declarations
const int fan = 8; //Fan pin declaration
int sen1 , sen2 ,sen3, sen4; //Sensor variables
int fanspeed;
void setup(){
//Set Led declararations as outputs
pinMode(L1, OUTPUT);
pinMode(L2, OUTPUT);
pinMode(L3, OUTPUT);
pinMode(L4, OUTPUT);
//Set sensor declararations as inputs
pinMode(S1,INPUT);
pinMode(S2,INPUT);
pinMode(S3,INPUT);
pinMode(S4,INPUT);
//Set Fan declaration as output
pinMode(fan,OUTPUT);
void loop(){
//Read all Sensors
sen1= digitalRead(S1);
sen2= digitalRead(S2);
sen3= digitalRead(S3);
sen4= digitalRead(S4);
if (sen1 == HIGH){
if (sen1 == HIGH){
fanspeed =255/4;
digitalWrite (L1, HIGH);
analogWrite (fan,fanspeed);
if (sen1 == HIGH && sen2 == HIGH){
fanspeed =255/2;
digitalWrite (L2, HIGH);
digitalWrite (L2, LOW);
digitalWrite (L3, LOW);
digitalWrite (L4, LOW);
if (sen1 == HIGH && sen2 == HIGH && sen3 == HIGH){
fanspeed =191;
digitalWrite (L3, HIGH);
if (sen1 == HIGH && sen2 == HIGH && sen3 == HIGH && sen4 == HIGH){
fanspeed =255;
digitalWrite (L4, HIGH);
else{
fanspeed =0;
analogWrite(fan,fanspeed);
digitalWrite (L1, LOW);
A second question : i have a project coming up with a lot of in en output's. is there a faster way to declare the pins then:
pinMode(9,OUTPUT);
Robin
