Hi, I'm working on my sensor, and I'm trying to save data to the sd card. I need the header/title data only in the first row of the stored data, how can I write the code, and where should it be placed? because if it is placed in a loop then it will appear continuously.
this is the code I made to read my sensor.
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
#define MQ2pin (A0)
float sensorValue; //variable to store sensor value
File myFile;
DS3231 rtc(SDA, SCL);
int pinCS = 10; // Pin 10 on Arduino Uno
pinMode(pinCS, OUTPUT);
// SD Card Initialization
if (SD.begin())
Serial.println("Gas sensor warming up!");
delay(2000); // allow the MQ-6 to warm up
Serial.println("SD card is ready to use.");
Serial.println("Time, sensor Value");
} else
Serial.println("SD card initialization failed");
return;
rtc.begin();
sensorValue = analogRead(MQ2pin); // read analog input pin 0
Serial.print(rtc.getDateStr()); //prosedur pembacaan tanggal
Serial.print(",");
Serial.print(rtc.getTimeStr()); //prosedur pembacaan waktu
Serial.print(",");
Serial.print(sensorValue);
Serial.println(" ");
myFile = SD.open("File1.txt", FILE_WRITE);
if (myFile) {
myFile.print(rtc.getDateStr());
myFile.print(",");
myFile.print(rtc.getTimeStr());
myFile.print(",");
myFile.print(sensorValue);
myFile.println(" ");
myFile.close(); // close the file
// if the file didn't open, print an error:
else {
Serial.println("error opening test.txt");
and this is the output
result that i want
