TLC connection
Hi, what are the other options of TLC5940 connection to arduino duemilanove?
Connection like in the foto isn't good for me.
thanks.
http://tlc5940arduino.googlecode.com/svn/wiki/images/breadboard-arduino-tlc5940_close.png
Whats not working for you? The circuit described in the picture works perfectly.
it works, but I need free 11 PIN
like this: http://pixelriot.com/pmatp/system/files/images/Arduino-5940_pins_closeup_0.jpg
but this don't work for me, so I need another.
Using what code? What did happen? What did you expect to happen? "It didn't work" is pretty lame. It conveys no information at all.
what should I do? I need free 11 pin
Post your code. Explain what happened when you ran it.
In response to your PM, if the guy that made this http://pixelriot.com/pmatp/system/files/images/Arduino-5940_pins_closeup_0.jpg made it work, then there is no reason that you can't. I don't have a TLC5940, so I can't test it, and if you don't post your code, we can't see if it can be modified to use the pins you want to use.
Take a look at tlc_config.h in the TLC5940 library, it supports changing the hardware pinouts (have a look at \libraries\Tlc5940\pinouts\chip_includes.h) and bit-banging which is SPI via software.
/** Determines how data should be transfered to the TLCs.  Bit-banging can use  any two i/o pins, but the hardware SPI is faster.
    - Bit-Bang = TLC_BITBANG
    - Hardware SPI = TLC_SPI (default) */
#define DATA_TRANSFER_MODE    TLC_SPI
/* This include is down here because the files it includes needs the data
   transfer mode */
#include "pinouts/chip_includes.h"
/* Set DATA_TRANSFER_MODE to TLC_BITBANG and change the pins below if you need
   to use different pins for sin and sclk.  The defaults are defined in
   pinouts/ATmega_xx8.h for most Arduino's. */
#if DATA_TRANSFER_MODE == TLC_BITBANG
/** SIN (TLC pin 26) */
#define SIN_PIN        DEFAULT_BB_SIN_PIN
#define SIN_PORT       DEFAULT_BB_SIN_PORT
#define SIN_DDR        DEFAULT_BB_SIN_DDR
/** SCLK (TLC pin 25) */
#define SCLK_PIN       DEFAULT_BB_SCLK_PIN
#define SCLK_PORT      DEFAULT_BB_SCLK_PORT
#define SCLK_DDR       DEFAULT_BB_SCLK_DDR
#endif
Hope this helps!
Having taken a look at the actual post you're working from, I think the confusion arises from the fact the the poster of the original article is not using a library to drive the TLC5940. He is doing it all himself, and you'll be able to use the same pins as him. The picture in the Playground is for connecting a TLC5940 to an Arduino using the TL5940 library. You'll need to wire yours up exactly like his, and copy his code and it should work perfectly. I have a TLC5940 set up on a breadboard, so I can test the code with you if you have any trouble!
Good luck!
And the original article!
http://pixelriot.com/pmatp/node/15
Thank you really helped, but I'm just starting to play with arduino and I do not understand code.
If I put all code it works for me, but still don't understand how just turn one led
when I know it I can do waht I want with other leds.
Can you help me with it?
You'd be better off using the TLC library - it's fully documented!
Heres a pdf that deals with writing a library for the TLC - this is in essence what you'll be doing if you do not use the TLC library.
https://docs.google.com/viewer?a=v&q=cache:n7O0KxymqUIJ:flipmu.noisepages.com/files/2011/04/Demystifying-the-TLC5940.pdf+arduino+tlc5940+library&hl=en&gl=uk&pid=bl&srcid=ADGEESjOnENPhYbebwrrNlbG1FfYsgcnTd_5ZMpoSHmdQKGL_dlcnwy7bYVeRwnCI3HZqGMTPYek3uD75FSgYND9zKXiiU6gJ51iQBT04llMW5Z91MNZnD9ldzoGWHakTju_6nxXuNYH&sig=AHIEtbTQimrytpizMdT0lmVzEs23wZggTw
