I just got a few TLC5940's to play around with, and I have one working right now, but how do I set the current limiter on a per-pin basis?? I have an RGB led and I would like the red pin to have more current (or the blue and green pins less current) to get the brightness of all three colors to be the same... I think you use the DCPRG and VPRG pins on the Tlc5940 but I'm not sure exactlly how to do it...
UPDATE: ok so after a lot more reading, it seems you use Dot Correction to set the current for each pin. BUT, so far all I've found is a command Tlc.setAllDC() which sets all the pins to the same.
FIGUED IT OUT!! Scroll down to the 3rd to last post in this forum link for a working code example from the creator of the library! Redirecting to Google Groups
Yes, the library as it stands doesn't have support for setting the values differently
per LED, but you can always adapt it (and suggest the additions back to the original
author). The thread you found seems to cover the issues.
