TLC5940 Fades behavior.
Im using the TLC5940 in conjuction with an arduino to fade pairs of leds down a line in a wearables project. I have come across a bizarre problem that occurs after 12 cycles of the LED's fading. After the 12th cycle the sketch seems to crash as all the LED's power on permanently unless you hard reset the arduino. I do not know how to rectify this and have tried many things. Is the buffer becoming full? if so how do i reset it? Any clue on whats going wrong or how i can solve it would be most appreciated. My setup is like http://students.washington.edu/acleone/codes/tlc5940arduino/img/breadboard-arduino-tlc5940_close.png Here is my code:
 #include "Tlc5940.h"
#include "tlc_fades.h"
TLC_CHANNEL_TYPE channel;
boolean resetFades = true;
void setup (){
  /* Call Tlc.init() to setup the tlc.
     You can optionally pass an initial PWM value (0 - 4095) for all channels.*/
  Tlc.init();
void loop () {
  // Tlc.clear();
   channel = 0;
     if (resetFades == true ) {
       resetFades = false;
      uint16_t duration = 900;                                               //fade length
      // Change these for pairs of LEDS
      uint32_t startMillis = millis() + 50;
      uint32_t endMillis = startMillis + duration;
      fadePairs(0,  startMillis, endMillis, duration, 100, 100); //Adjust Brightnesses of the Individual LED's in a pair.
      startMillis = millis() + 300;
      fadePairs(2,  startMillis, endMillis, duration, 200, 200);
      startMillis = millis() + 600;
      fadePairs(4,  startMillis, endMillis, duration, 300, 300);
      // Fade in twos
      //LED 0
      //tlc_addFade(channel, 0, maxValueB, startMillis, endMillis); //fade in
      //tlc_addFade(channel, maxValueB, 0, endMillis, endMillis + duration);// fade out
      //tlc_addFade(channel+1, 0, maxValueR, startMillis, endMillis); //fade in
      //tlc_addFade(channel+1, maxValueR, 0, endMillis, endMillis + duration);// fade out
      Serial.println("resetting");
     int fadesRemaining = tlc_updateFades();
     if (!fadesRemaining){
       // all fades are done
       resetFades = true;
     delay(25);
      Tlc.update();
//Our LED fading function
void fadePairs(TLC_CHANNEL_TYPE channel, int startMillis, int endMillis, int duration, int maxValueR, int maxValueB){
any help would be appreciated . Thanks.
help is more forthcoming it you DON'T cross post. >:(
