It turns out there is a function in the library to set the dot correction (DC) from progmem: tlc_setDCfromProgmem, which operates much like Tlc.setAllDC but allows setting of the dot correction values (0-63) for each LED channel. This seems very close to what I want. Thanks (again) to Alex for pointing this out. Alas, there are two problems:
- Tlc.setAllDC and tlc_setDCfromProgmem give different behavior for the same inputs. Weird. I think Tlc.setAllDC is right.
- The DC behavior is lost as soon as a GS call (like Tlc.setAll followed by Tlc.update) is made. The data sheet says that the DC data should stick, so I'm wondering what the problem could be. Perhaps the latch pulse isn't firing at the right time?
Here's some of the early behavior. This first one sets the DC to a very low intensity level, but the LEDs turn back on to full brightness after about 2 seconds, presumably when the Tlc.update gets called:
Tlc.init(0);
Tlc.update();
delay(100);
Tlc.setAllDC(1); // this gives all off for 0, and all very dim for 1
delay(2000);
Tlc.setAll(4095);
Tlc.update(); // at this update the DC information is lost
If I change the input to the Tlc.setAllDC(1) from 1 to 0 the LEDs are completely off, as expected. The problem here is that the GS call (Tlc.setAll and Tlc.update) appears to wipe out the DC information set earlier.
Here's a 2nd version using tlc_setDCfromProgmem. This has the same behavior as above (GS commands wiping out the DC commands) but also all of the LEDs are much brighter for DC setting of 1 (out of a max of 63) and the LEDs are still on even when the DC value is set to 0:
const prog_uint8_t iDC = 0;
prog_uint8_t dcArray1[NUM_TLCS * 12] = {
DC_QUARTET(iDC, iDC, iDC, iDC), DC_QUARTET(iDC, iDC, iDC, iDC),
Tlc.init(0);
Tlc.update();
delay(100);
tlc_setDCfromProgmem(dcArray1); // this does NOT give all off for 0, fairly bright for 1
delay(2000);
Tlc.setAll(4095);
I'm a bit out of my depth working inside of the library, but I need to figure this out. If anyone has any suggestions, tips or resources, I would appreciate a push in the right direction.
