Ok, I'm struggling to understand if this can be done or not. Currently I have a 3 TLC5940's running on ports 13,11,10,9, and 3. I would like to add an ENC28J60 Ethernet chip to the mix but I believe its a SPI interface which uses 10,11,12,13 and 2 for chip select. Now I understand you can change the TLC5940 library to use bitbang instead of hardware SPI however, it will only let you change pin 13 and 11, not 10(BLANK). If I want to use the ENC28J60 I have to use hardware SPI which includes pin 10. What is pin 10(BLANK) used for and can it be changed or used at the same time?
Elf
