I'm plan to drive 5x8 rgb led matrix with Mega 2560. Almost there with TLC5940Mux.h, but raw 3 and raw 7 is not functioning... Other all raws are fine and act as expected...
Please help if anyone can ...
#include "Tlc5940Mux.h"
#define NUM_TLCS 1
#define NUM_ROWS 8
// SHIFT_DATA_PIN (PC0 is analog 0) = '595 SER pin (Pin 14)
#define SHIFT_DATA_PORT PORTC
#define SHIFT_DATA_PIN PC0
#define SHIFT_DATA_DDR DDRC
// SHIFT_CLK_PIN (PC1 is analog 1) = '595 SRCLK (Pin 11)
#define SHIFT_CLK_PORT PORTC
#define SHIFT_CLK_PIN PC1
#define SHIFT_CLK_DDR DDRC
// '595 RCLK is hooked to tlc XLAT pin (Arduino digital Pin 9, 74HC595 Pin 12)
volatile uint8_t isShifting;
uint8_t shiftRow;
static inline void shift8_595_row(uint8_t row)
// the output of the '595 for the selected row should be high, all others
// low
uint16_t output = (1 << row);
uint16_t nbit = 1 << (NUM_ROWS - 1); //0x80;
for (; nbit; nbit >>= 1) {
if (nbit & output) {
SHIFT_DATA_PORT |= _BV(SHIFT_DATA_PIN);
else {
SHIFT_DATA_PORT &= ~_BV(SHIFT_DATA_PIN);
// pulse the '595 sclk
SHIFT_CLK_PORT |= _BV(SHIFT_CLK_PIN);
SHIFT_CLK_PORT &= ~_BV(SHIFT_CLK_PIN);
ISR(TIMER1_OVF_vect)
if (!isShifting) {
disable_XLAT_pulses();
isShifting = 1;
sei();
TlcMux_shiftRow(shiftRow);
shift8_595_row(shiftRow);
PORTC = shiftRow++;
if (shiftRow == NUM_ROWS) {
shiftRow = 0;
enable_XLAT_pulses();
isShifting = 0;
void test()
for(int x=0; x<8; x++){
TlcMux_clear();
TlcMux_set(x, 0, 4095);
delay(100);
TlcMux_clear();
TlcMux_set(x, 1, 4095);
delay(100);
TlcMux_clear();
TlcMux_set(x, 2, 4095);
delay(100);
SHIFT_DATA_DDR |= _BV(SHIFT_DATA_PIN);
SHIFT_CLK_DDR |= _BV(SHIFT_CLK_PIN);
DDRC |= _BV(PC0) | _BV(PC1) | _BV(PC2);
TlcMux_init();
uint8_t color;
delay(1);
for (uint8_t col = 0; col < 11; col++) {
for (uint8_t row = 0; row < NUM_ROWS; row++) {
TlcMux_set(row, col + color * 16, 4095);
color++;
if (color == 3) {
color = 0;
test();
