TLE4905L
Hello,
How to connect 4905 hall sensor on digital pin? What do i need for wiring that and how?
Thanks,
teo
Do you have a link to the datasheet?
Here it is Infineon 1-tle4905l datasheet pdf
Pin Vs to +5V
Pin Gnd to arduino ground
Pin Q to any arduino digital input expect 0 & 1
Enable the internal pull up resistor, by doing a digitalWrite HIGH to the input pin you use, in the setup()
Then read it like the button sketch.
Thanks, this was much easier than I thought.. Tested, and working great of course..
I don t want to open new topic, but i have more questions..
How to connect LM35DZ http://www.ti.com/lit/ds/symlink/lm35.pdf
And how to connect LM335Z http://www.ti.com/lit/ds/symlink/lm135.pdf
Both connecting to analog...
What is the difference between those two? The difference that I think I see is that for the 335 I only need two wires, and for the 35, I need three, and both need to use some resistance to the connection... Or I am wrong?
Again thanks for the prompt answer!
Figure 1 on page 2 of the data sheet with the output feeding directly into one of the analogue inputs.
Basic sensor on page 6 of the data sheet with the output feeding directly into one of the analogue inputs.
Well it is all in the data sheet, but basically the LM135 gives you one degree accuracy and the LM35 gives you half a degree accuracy.
