TM1637 and Jumbo Display
Aaaah finally I could find a way to start a new topic.
I need to make a jumbo display of 6" size with TM1637.
Primary reason to use TM1637 is my software and hardware (used CATALEX 7 segment display module of 4 digits) has been tested with it. I am happy with the result.
To scale is up to a jumbo module, I have done the circuit as per the schematic attached.
Just to remind, Each segment has 2 rows of 10 LED's with a current limiting resistor for each row.
Although the circuit shows only one segment (A1), I have 3 segments (A2 and A3) as well.
Before I power it up, I want your opinion on the correctness.
Please suggest.
thanks,
Madhav
Display driver board for forum.pdf (50.1 KB)
Use a TPIC6B595 instead of that part and all the discrete parts.
Same as writing to 74HC595 shift register, only it has 150mA outputs rated to 50V.
digitalWrite (latchPin, LOW);
SPI.transfer (fontArray[yourNumber]);
digitalWrite (latchPin, HIGH);
or this if time is not a concern
shiftOut (dataPin, clockPin, MSBFIRST, fontArray[yourNumber]);
I'm facing exactly the same problem.
Just wanted to ask if your schematic based on TM1637 works ?
