Tm1637 GPS clock
//TM1637 GPS clock
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include "SevenSegmentTM1637.h"
#include "SevenSegmentExtended.h"
static const int RXPin = 5, TXPin = 6;  // TX -> D4, RX -> D3
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin);
const byte PIN_CLK = 2;   // define CLK pin (any digital pin)
const byte PIN_DIO = 3;   // define DIO pin (any digital pin)
SevenSegmentExtended      display(PIN_CLK, PIN_DIO);
int Satellites = 12;
int hours = 0;
int minutes = 0;
int wasMinute = 99; // used for blanking leading zero
int DSTEST = 8;//GMT+8
int TwelveTwentyFour = 24;
 ss.begin(GPSBaud);
 display.begin();            // initializes the display
 display.setBacklight(100);  // set the brightness to 100 %
 delay(1000);                // wait 1000 ms
 hours = 99;
 minutes = 99;
 display.printTime(hours, minutes, true);  // display time
 pinMode(Satellites, INPUT_PULLUP);
 while (ss.available() > 0)
   if (gps.encode(ss.read()))
     displayInfo();
 if (millis() > 5000 && gps.charsProcessed() < 10)   {
   Serial.println(F("No GPS detected: check wiring."));
   while (true);
void displayInfo() {
 int SW5 = digitalRead(Satellites);
 if (SW5 == LOW) {
   display.print("Sat=");
   display.clear();
   int temp = gps.satellites.value();
   Serial.print("temp = ");
   Serial.println(temp);
   display.print(gps.satellites.value());
   Serial.print("Satellites Seen = ");
   Serial.println(gps.satellites.value());
 Serial.print(F("Location: "));
 if (gps.location.isValid())  {
   Serial.print(gps.location.lat(), 6);
   Serial.print(F(","));
   Serial.print(gps.location.lng(), 6);
   Serial.print(F("INVALID"));
 Serial.print(F("  Date/Time: "));
 if (gps.date.isValid())   {
   Serial.print(gps.date.month());
   Serial.print(F("/"));
   Serial.print(gps.date.day());
   Serial.print(gps.date.year());
 Serial.print(F(" "));
 if (gps.time.isValid())   {
   if (gps.time.hour() < 10) Serial.print(F("0"));
   Serial.print(gps.time.hour() + 9 ); // time ZONE mod
   Serial.print(F(":"));
   if (gps.time.minute() < 10) Serial.print(F("0"));
   Serial.print(gps.time.minute());
   if (gps.time.second() < 10) Serial.print(F("0"));
   Serial.print(gps.time.second());
   Serial.print(F("."));
   if (gps.time.centisecond() < 10) Serial.print(F("0"));
   Serial.print(gps.time.centisecond());
/////////////////To Clock LED Display/////////////////////////////
   int hours = gps.time.hour();
   Serial.print(" DST = ");
   Serial.print(DSTEST);
   int timezonehr = DSTEST;
   hours = hours + timezonehr;
   if (hours > TwelveTwentyFour - 1) {
     hours = hours - TwelveTwentyFour;
     if (hours == 0) hours = 12; // make sure shows 12 at noon
   else {
     if (hours < 0) {
       hours = hours + TwelveTwentyFour;
   int minutes = gps.time.minute();
   if (minutes  != wasMinute) {
     Serial.print("Hours just before sent to LED ");
     Serial.println(hours);
     display.printTime(hours, minutes, false);  // display time
     if (   hours <= 9) {
       display.print(" ");
     wasMinute = minutes;
Do you have a question ?
I suspect you're having problems processing gps text strings. Please read:
No I just want to share my code to you
Was this the subject of a previous thread? If so, then please post it there, as a followup.
Otherwise, perhaps it should go to showcase, though for that it should have at minimum a complete schematic, and textual description.
