TM1637 Help
I'm hoping you all could help me with my project. I may not have the right library or anything, but i'm having trouble getting this code to display numbers counting up with a TM1637.
Here is my code...
#include <TM1637Display.h>
#define CLK 3
#define DIO 2
TM1637Display display(CLK,DIO);
display.set(5);
display.init(D4056A);
pinMode(2, OUTPUT);
int v=1;
while (v<=9999 )
display.display(v);
v = v + 1;
and here is the error message I keep getting.
G:\PC_Based_Oscilloscope_Using_Arduino\Sketch\pcscope\pcscope.ino: In function 'void loop()':
pcscope:24: error: 'class TM1637Display' has no member named 'display'
display.display(v);
exit status 1
'class TM1637Display' has no member named 'set'
i'm very VERY new to arduino coding. HELP HELP!
Hi.
First of all, please, edit your post and use the code button for insert your code.
TM1637 is a 7 segment display?
Please post more information.
If are 7 segment display I see on library that not appears set(), or display(), but I see showNumberDec()
