TM1637 with potentiometer, milliseconds
Hello......
I've been programming lately, I want to ask if anyone can help me with this code? These are two codes I want to work as one. By turning the potentiometer, I want the milliseconds displayed on the display to affect the button. The button currently controls the relay and LED for 70 milliseconds.
#include <TM1637Display.h>
#define CLK 9
#define DIO 8
TM1637Display display(CLK, DIO);
int dly = 0; // Set Delay time before next Upshift
int i = 0; // Don't Touch!
int cutoff = 70 ; // Set Engine Cutoff time (If you're using relay, do not set timing under 40ms)
Serial.begin(9600); // initialize serial communication at 9600 bits per second:
display.setBrightness(3);
pinMode(A0, INPUT);
pinMode(2, INPUT_PULLUP);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
void loop(){
unsigned int potVal = 0; // reset
for (int i = 0; i < 64; i++) { // 64 analogue readings
potVal += analogRead(A0); // add each value
potVal = map(potVal, 65472, 0, 41, 301); // pot wires reversed ?
// potVal = map(potVal, 0, 65472, 0, 1000); // use this if connected 'normal'
display.showNumberDec(potVal, true);
int snsrstate=digitalRead(2);
if (snsrstate==HIGH) {
i=0;
delay(50);
if (snsrstate==LOW && i==0) {
i+=1;
digitalWrite(5, LOW);
digitalWrite(6, HIGH);
delay(cutoff);
digitalWrite(5, HIGH);
digitalWrite(6, LOW);
delay(dly);
proben.ino (1.13 KB)
Can no one help ???
