TM1638 7 segment led board - cannot get it to loop
Hello everyone
I am new to this … but am learning a little at a time
I recently started playing around with a led&key circuit board with a uno board
I think its a TM1638
I have written this code but wanted it to turn the screen off and loop again constantly
I think I have gone wrong somewhere.
so the scenario of what i wanted it to do is
light up the leds and segments as “0” which it does
and then clear the screen and do the same again over and over
const int strobe = 7;
const int clock = 9;
const int data = 8;
void sendCommand(uint8_t value)
digitalWrite(strobe, LOW);
shiftOut(data, clock, LSBFIRST, value);
digitalWrite(strobe, HIGH);
void reset()
sendCommand(0x40); // set auto increment mode
shiftOut(data, clock, LSBFIRST, 0xc0); // set starting address to 0
for(uint8_t i = 0; i < 16; i++)
shiftOut(data, clock, LSBFIRST, 0x00);
pinMode(strobe, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(data, OUTPUT);
sendCommand(0x8f); // activate and set brightness to max
reset();
sendCommand(0x44); // set single address
shiftOut(data, clock, LSBFIRST, 0x3F); // 1st segment 0x3F address is first segment 0x3F displaying 0
delay (200);
shiftOut(data, clock, LSBFIRST, 0xc9); // 5th LED
shiftOut(data, clock, LSBFIRST, 0x01);
delay (200);
shiftOut(data, clock, LSBFIRST, 0xc2); // 2nd segment 0xc2 address is 2nd segment 0x3F displaying 0
delay (200);
shiftOut(data, clock, LSBFIRST, 0xc7); // 4th LED OFF
delay (200);
shiftOut(data, clock, LSBFIRST, 0xc4); // 3rd segment 0xc4 address is 3rd segment 0x3F displaying 0
delay (200);
shiftOut(data, clock, LSBFIRST, 0xc5); // 3rd LED on
delay (300);
shiftOut(data, clock, LSBFIRST, 0xc3); // 2nd LED
delay (200);
shiftOut(data, clock, LSBFIRST, 0xc6); // 4thsegment 0xc6 address is 4th segment 0x3F displaying 0 4th
delay (200);
shiftOut(data, clock, LSBFIRST, 0xc1); // 1st LED
delay (200);
shiftOut(data, clock, LSBFIRST, 0xc8); // 1st segment 0xc8 address is 5th segment 0x3F displaying 0 5th
delay (200);
if someone could help me I would be so thankful
thanks for your time
Mark
Hi, Welcome to the forum.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code. It will be formatted in a scrolling window that makes it easier to read.
If you google TM1638 You will find a library for the display that will make your code so much easier. Here;
https://github.com/rjbatista/tm1638-library
Thanks... Tom... :)
