Hi
I have this shield for arduino uno.
library I've been.
has anyone good sketches here for?
thanks
Hi
library I've been.
thanks
First.. Terminology. Knowing this will save you time and frustration.
Not a shield. Shields plug into an Arduino or pin compatible board. Which could explain why you are having a problem finding information.
This is a module. Not Arduino specific, And it only has 4 wires to talk to the controller chip, which does much of the tricky stuff. If anything, this makes it more useful, as it will usually be cheaper than a shield, and you can choose what pins you use, and incorporate it in a DIY circuit instead of building a bought Arduino into a permanent project.
This is one of many boards produced usually by Chinese hobby electronics suppliers, and based on a Chinese driver chip. Low price, lots of functionality, little documentation.
Good news.. Only 2 Arduino pins are taken up. The other two are power. So should add lots of scope to add it to your projects.
Bad news, it's a wee bit more involved than sending "hello" to the 7 segment display.
Do a search on this forum for "TM1638". Or Google it, and you will come across a whole bunch of Arduino specific tutorials, and a range of similar modules using the same chips.
There is a library for driving the display chip, so it should be pretty easy.
Hi
I have among between a zip file of the Chinese had.
but is in the C language, and so I do not know how to do it to the arduino, thus to get working.
and of course everything in Chinese.
the zip is attached
and I can't find this library they use
#include <REGX51.H>
I see on google that REGX51. h of the c language is
I ask someone who can convert the whole thing in that zip,
or is that asking too much??
so that it works normally with arduino uno
TM1638 按键数码管模块.zip (802 KB)
