TM1650 7-Segment Display. How to suppress leading zeros?
I am using maxin-rd/TM16xx library.
This is my test-code:
#include <TM1650.h>
#include <TM16xxDisplay.h>
//              [data Pin]
//              |  [clock Pin]
//              |  |  [num Digits]
//              |  |  |  [activate Display]
//              |  |  |  |     [intensity]
//              |  |  |  |     |  [display mode]
TM1650 display1(4, 5, 4, true, 0);
int n;
  display1.clearDisplay();
  for (n = 0; n < 9999; n++) {
    display1.setDisplayToDecNumber(n, 0);
    delay(300);
setDisplayToDecNumber() doesn't suppress leading zeros.
I have seen an example at this video that is using setDisplayToSignedDecNumber ().
   display1.setDisplayToSignedDecNumber( n,       // signed long number
                                         B0000,   // byte dots
                                         false    // boolean leadingZeros = true
                                               ); // const byte numberFont[] = TM16XX_NUMBER_FONT);
It seems like that instruction can suppress the leading zeros, but I get an error when I introduce that line.
Compilation error: 'class TM1650' has no member named 'setDisplayToSignedDecNumber'; did you mean 'setDisplayToDecNumber'?
That library does not contain that keyword. Is there other library that can suppress leading zeros?
If you take a look in TM16xx/src/TM16xxDisplay.h you'll find the following in the TM16xxDisplay class:
  // Set the display to a unsigned hexadecimal number (with or without leading zeros)
  void setDisplayToHexNumber(unsigned long number, byte dots, boolean leadingZeros = true, const byte numberFont[] = TM16XX_NUMBER_FONT);
  // Set the display to a unsigned decimal number (with or without leading zeros)
  void setDisplayToDecNumber(unsigned long number, byte dots, boolean leadingZeros = true, const byte numberFont[] = TM16XX_NUMBER_FONT);
  // Set the display to a signed decimal number (with or without leading zeros)
  void setDisplayToSignedDecNumber(signed long number, byte dots, boolean leadingZeros = true, const byte numberFont[] = TM16XX_NUMBER_FONT);
and if you take a look in the some of the examples you'll find code similar to:
TM1650 module(4, 5, 4, true, 0);
TM16xxDisplay display(&module, 4);
display.setDisplayToSignedDecNumber(n, 0b0000, false);
Thank you for your reply.
Yes, I have already tried
But as I have stated above, I get the error:
Your code:
Code from examples. Notice the difference?
My mistake! :sweat_smile:
Working now
Thank you very much for your kind support.
