Hi I'm just trying to get some practice in configuring and using the UART interface for a tmc2209 but struggling a bit.
I have done a bit of digging around but with no success.
I'm unable to get any communication between the driver and my uno. Because I want to use the hardware serial to read the serial on my pc I tried setting up software serial however this didn't seem to work and there were no changes in the readings from the driver.
Im using a bigtreetech driver
The code I was using was: (adapted from the TMCStepoer library example)
#include <SoftwareSerial.h>
#include <AccelStepper.h>
AccelStepper stepper = AccelStepper(1, 9, 8);
SoftwareSerial Serial1 (6, 7);
* Author Teemu Mäntykallio
* Plot TMC2130 or TMC2660 motor load using the stallGuard value.
* You can finetune the reading by changing the STALL_VALUE.
* This will let you control at which load the value will read 0
* and the stall flag will be triggered. This will also set pin DIAG1 high.
* A higher STALL_VALUE will make the reading less sensitive and
* a lower STALL_VALUE will make it more sensitive.
* You can control the rotation speed with
* 0 Stop
* 1 Resume
* + Speed up
* - Slow down
#include <TMCStepper.h>
#define MAX_SPEED 40 // In timer value
#define MIN_SPEED 1000
#define STALL_VALUE 10 // [0..255]
#define EN_PIN 12 // Enable
#define DIR_PIN 8 // Direction
#define STEP_PIN 9 // Step
#define SW_RX 6 // TMC2208/TMC2224 SoftwareSerial receive pin
#define SW_TX 7 // TMC2208/TMC2224 SoftwareSerial transmit pin
#define SERIAL_PORT Serial1 // TMC2208/TMC2224 HardwareSerial port
#define DRIVER_ADDRESS 0b00 // TMC2209 Driver address according to MS1 and MS2
#define R_SENSE 0.11f // Match to your driver
// SilentStepStick series use 0.11
// UltiMachine Einsy and Archim2 boards use 0.2
// Panucatt BSD2660 uses 0.1
// Watterott TMC5160 uses 0.075
// Select your stepper driver type
//TMC2209Stepper driver(&SERIAL_PORT, R_SENSE, DRIVER_ADDRESS);
TMC2209Stepper driver(SW_RX, SW_TX, R_SENSE, DRIVER_ADDRESS);
using namespace TMC2208_n;
// Using direct register manipulation can reach faster stepping times
#define STEP_PORT PORTB // Match with STEP_PIN
#define STEP_BIT_POS 9 // Match with STEP_PIN
ISR(TIMER1_COMPA_vect){
//STEP_PORT ^= 1 << STEP_BIT_POS;
digitalWrite(STEP_PIN, !digitalRead(STEP_PIN));
Serial.begin(250000); // Init serial port and set baudrate
while(!Serial); // Wait for serial port to connect
Serial.println("\nStart...");
SERIAL_PORT.begin(115200);
driver.beginSerial(115200);
pinMode(EN_PIN, OUTPUT);
pinMode(STEP_PIN, OUTPUT);
pinMode(DIR_PIN, OUTPUT);
digitalWrite(EN_PIN, LOW);
driver.begin();
driver.toff(4);
driver.blank_time(24);
driver.rms_current(400); // mA
driver.microsteps(16);
driver.TCOOLTHRS(0xFFFFF); // 20bit max
driver.semin(5);
driver.semax(2);
driver.sedn(0b01);
driver.SGTHRS(STALL_VALUE);
// Set stepper interrupt
cli();//stop interrupts
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
OCR1A = 256;// = (16*10^6) / (1*1024) - 1 (must be <65536)
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS11 bits for 8 prescaler
TCCR1B |= (1 << CS11);// | (1 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
stepper.setSpeed(400);
stepper.runSpeed();
static uint32_t last_time=0;
uint32_t ms = millis();
while(Serial.available() > 0) {
int8_t read_byte = Serial.read();
#ifdef USING_TMC2660
if (read_byte == '0') { TIMSK1 &= ~(1 << OCIE1A); driver.toff(0); }
else if (read_byte == '1') { TIMSK1 |= (1 << OCIE1A); driver.toff(driver.savedToff()); }
#else
if (read_byte == '0') { TIMSK1 &= ~(1 << OCIE1A); digitalWrite( EN_PIN, HIGH ); }
else if (read_byte == '1') { TIMSK1 |= (1 << OCIE1A); digitalWrite( EN_PIN, LOW ); }
#endif
else if (read_byte == '+') { if (OCR1A > MAX_SPEED) OCR1A -= 20; }
else if (read_byte == '-') { if (OCR1A < MIN_SPEED) OCR1A += 20; }
if((ms-last_time) > 100) { //run every 0.1s
last_time = ms;
Serial.print("0 ");
Serial.print(driver.SG_RESULT(), DEC);
Serial.print(" ");
Serial.println(driver.cs2rms(driver.cs_actual()), DEC);
Can you spot anything I'm doing wrong?
Also, could someone clarify what this line means, I don't understand it.
Thanks in advance.
Please do let me know if Im not giving enough information.
