tmElements
sir/maam: how to fix this "tmElements_t was not declared in this scope" what is the problem of this?? thank you
I can see nothing wrong with the code that you have not posted.
Please read this before posting a programming question
The problem is that tmElements was not declared in the scope in which it was used.
See hsnippets-r-us.com
this is the code:
#include <Wire.h>
#include <Time.h>
#include <DS1307RTC.h>
const char *monthName[12] = {
“Jan”, “Feb”, “Mar”, “Apr”, “May”, “Jun”,
“Jul”, “Aug”, “Sep”, “Oct”, “Nov”, “Dec”
tmElements_t tm;
bool parse=false;
bool config=false;
// get the date and time the compiler was run
if (getDate(DATE) && getTime(TIME)) {
parse = true;
// and configure the RTC with this info
if (RTC.write™) {
config = true;
while (!Serial) ; // wait for Arduino Serial Monitor
delay(200);
if (parse && config) {
Serial.print(“DS1307 configured Time=”);
Serial.print(TIME);
Serial.print(", Date=");
Serial.println(DATE);
} else if (parse) {
Serial.println(“DS1307 Communication Error :-{”);
Serial.println(“Please check your circuitry”);
Serial.print(“Could not parse info from the compiler, Time=”");
Serial.print(TIME);
Serial.print("", Date="");
Serial.print(DATE);
Serial.println(""");
bool getTime(const char *str)
int Hour, Min, Sec;
if (sscanf(str, “%d:%d:%d”, &Hour, &Min, &Sec) != 3) return false;
tm.Hour = Hour;
tm.Minute = Min;
tm.Second = Sec;
return true;
bool getDate(const char *str)
char Month[12];
int Day, Year;
uint8_t monthIndex;
if (sscanf(str, “%s %d %d”, Month, &Day, &Year) != 3) return false;
for (monthIndex = 0; monthIndex < 12; monthIndex++) {
if (strcmp(Month, monthName[monthIndex]) == 0) break;
if (monthIndex >= 12) return false;
tm.Day = Day;
tm.Month = monthIndex + 1;
tm.Year = CalendarYrToTm(Year);
return true;
when i trying to upload this on my arduino uno with also a rtc module the said error has been pop up.
Is that the full text of the error message ?
tmElements_t is a structure declared in TimeLib.h
You need to have the Time-Master folder in your libraries path and then include both the Time and TimeLib headers, in your sketch.
#include <Time.h>
#include <TimeLib.h>
tmElements_t tmNow;
#include <Time.h>
tmElements_t tmNow;#]
Works for me
MattS-UK: You need to have the Time-Master folder in your libraries path and then include both the Time and TimeLib headers, in your sketch.
It's good form to rename xxx-Master to xxx, where xxx is the name of the library. I keep all my master libraries in another folder for future use and to keep them clean in case I modify something in a library.
You don't have to include TimeLib.h.
