TMP175 Convert Celcius to farenheit
i was wondering if any one knows how to convert this to output farenheit instead of celcius . i have tried but havent gotten it to work .
i have tried adding TempHi*1.8+32 but i dont think that is correct
#include <Wire.h>
byte TempHi;              // Variable hold data high byte
byte TempLo;              // Variable hold data low byte
boolean P_N;              // Bit flag for Positive and Negative
unsigned int Decimal;     // Variable hold decimal value
void Cal_Temp();
  Wire.begin();             // join i2c bus (address optional for master)
  const int I2C_address = 55;  // I2C write address
  delay(100);
  Wire.beginTransmission(I2C_address);
  Wire.send(1);             // Setup configuration register
  Wire.send(0x60);          // 12-bit
  Wire.endTransmission();
  Wire.send(0);             // Setup Pointer Register to 0
  while (1)
    delay(10);
    // Read temperature value
    Wire.requestFrom(I2C_address, 2);
    while(Wire.available())          // Checkf for data from slave
      TempHi = Wire.receive();       // Read temperature high byte
      TempLo = Wire.receive();       // Read temperature low byte
    Cal_Temp ();
    // Display temperature
    Serial.print("The temperature is ");
    if (P_N == 0)
      Serial.print("-");
    Serial.print(TempHi,DEC);
    Serial.print(".");
    Serial.print(Decimal,DEC);
    Serial.println(" degree C");
void Cal_Temp()
  if (TempHi&0x80)          // If bit7 of the TempHi is HIGH then the temperature is negative
    P_N = 0;
  else                      // Else the temperature is positive
    P_N = 1;
  TempHi = TempHi & 0x7F;   // Remove sign
  TempLo = TempLo & 0xF0;   // Filter out last nibble
  TempLo = TempLo >>4;      // Shift right 4 times
  Decimal = TempLo;
  Decimal = Decimal * 625;  // Each bit = 0.0625 degree C
you will have to make "Decimal" a float variable , not an unsigned integer if you are multiplying by 1.8
but how would i get it to devide right? i tried
Serial.print(TempHi*1.8+32,DEC);
    Serial.print(".");
but it adds 2 decimal points and when i take out Serial.print("."); it looks like its off but i dont have a digital temp gun but i just think im messing it up.
I am not sure that Serial.print() can handle expressions.
After looking at your code (correct me if I am wrong) but it looks like the temperature data is read in two bytes, TempHi which is the integer value (left of the decimal point) of the temp in Celsius and TempLo which is the decimal value (right of the decimal) in integer multiples of .0625 degrees C.
not sure about this code though
What I would do is to first combine them into one floating point variable.
float combined_temp_C;
combined_temp_C= TempHi + TempLo*.0625;
then Try this......
float combined_temp_F;  //create a new variable
combined_temp_F = combined_temp_c*1.8+32;  //set new variable to expression
Serial.printIn( newvariable, 2);  //where 2 means print up to 2 decimal places, but can be whatever you want
thanx alot man that worked perfect :wink: :sunglasses: i didnt think to try it like that but im still learning to mess with the arduino THANX alot man and heres my code if anyone else is interested . its for TMP175 from ti.com and turns a fan connected to a transistor on or off depending on the temp
Example program I2C-TMP interface with Arduino.
SETUP:    I2C-TMP => Arduino
          PIN3 => ground, PIN4 => A5(SCL), PIN5 => A4(SDA), PIN6 => +5V
Note:     The program is written for address 0x90 (Arduino address 0x48).
          This program was tested using Arduino Nano
Document: TMP175 datasheet
Updated:  September 4, 2008
E-mail:   support@gravitech.us
          Gravitech
(C) Copyright 2008 All Rights Reserved
#include <Wire.h>
float combined_temp_c;
int ventpin = 9;
void Cal_Temp();
                      Setup
   pinMode(ventpin,OUTPUT);
                      Main Loop
  delay(100);
  while (1)
    delay(10);
    Cal_Temp ();
    if (P_N == 0)
      Serial.print("-");
    Serial.println(combined_temp_F,DEC);
    if (TempHi*1.8+32 > 80 ){
      analogWrite(ventpin, 255);
      if (TempHi*1.8+32 < 80 ){
      analogWrite(ventpin, 0);
void Cal_Temp()
    P_N = 0;
    P_N = 1;
  Decimal = TempLo;
  combined_temp_c= TempHi + TempLo*.0625;
no problem, I am glad it worked ;D
