TMP3- Uno connected to Raspberry Pi
I am getting incorrect readings from a TMP36 temperature sensor when connecting my Arduino Uno to a Raspberry Pi. With the Arduino connected to my laptop and the TMP36 connected to the 5V supply I get a sensor output of 135, which led to an accurate temperature using the following formula:
Sensor value =- sv Volts (V) = (sv/1024)*5 Temp = (V - 0.5)*100
When plugged into the RPi the sensor value is around 158. I tested the power pins on the Arduino and got 4.4V for the 5V pin and 3.3V for the 3.3V pin.
I tried connecting the TMP36 to the 3.3V pin and modified the formula to:
Sensor value =- sv Volts (V) = (sv/1024)*3.3 Temp = (V - 0.5)*100
However the sensor values are still the same, leading to a greater error on the calculated results.
I'll be able to post a photo of the setup when I get home from work this evening.
Any suggestions?
The TMP36 can be powered from 3.3volt or 5volt.
That should make no difference to the output voltage of the sensor (the temp).
It seems you measure the sensor with Arduino’s default Aref (5volt).
If that 5volt supply is not stable, the temp readings are also not stable.
Better to read these sensors with e.g. 1.1volt Aref, or an external reference voltage.
Here’s some code that uses 1.1volt Aref and smoothing.
Read the comments. You might have to adjust a few things.
Leo…
// TMP35 or TMP36 temp sensor connected to Analogue input A1, 3.3volt and ground
// or LM35 temp sensor connected to A1, 5volt and ground
// temp range ~2C to ~105C
// display on serial monitor and/or LCD
// for a TMP36 (-40C to ~55C), change line 45 to:   tempC = total * Aref * 0.1 / numReadings - 50.0;
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); // your LCD pins could be different
byte ledPin = 10; // backlight pin
const byte numReadings = 32; // number of readings for smoothing (max 64)
int readings[numReadings]; // readings from the analog input
byte index = 0; // index of the current reading
unsigned int total = 0; // running total
int inputPin = A1; // the pin that the sensor is connected to
float Aref = 1.0759; // change this value to the actual Aref voltage of ---YOUR--- Arduino (1.0 - 1.2), or adjust to get accurate readings
float tempC; // Celcius
float tempF; // Fahrenheit
  //analogWrite(ledPin, 200); // optional dimming
  analogReference(INTERNAL); // use the internal ~1.1volt reference | change (INTERNAL) to (INTERNAL1V1) for a Mega
  Serial.begin(115200); // ---set serial monitor to this value---
  lcd.begin(16, 2); // shield with 2x16 characters
  lcd.print("Thermometer"); // info text
  lcd.setCursor(0, 1); // second row
  lcd.print("0-100 Celcius");
  for (index = 0; index < numReadings; index++) { // fill the array for faster startup
    readings[index] = analogRead(inputPin);
    total = total + readings[index];
  index = 0; // reset
  delay(2000); // info display time
  total = total - readings[index]; // subtract the last reading
  readings[index] = analogRead(inputPin); // one unused reading to clear ghost charge
  readings[index] = analogRead(inputPin); // read from the sensor
  total = total + readings[index]; // add the reading to the total
  index = index + 1; // advance to the next position in the array
  if (index >= numReadings) // if we're at the end of the array
    index = 0; // wrap around to the beginning
  // convert value to temp
  tempC = total * Aref * 0.1 / numReadings; // value to celcius conversion
  tempF = tempC * 1.8 + 32; // Celcius to Fahrenheit conversion
  // print to LCD
  if (total == 1023 * numReadings) { // if overflow
    lcd.clear();
    lcd.print("---TOO HOT---");
  else {
    lcd.clear();
    lcd.print(tempC, 2); // two decimal places
    lcd.setCursor(6, 0); // position 6, first row
    lcd.print("Celcius");
    lcd.print(tempF, 1); // one decimal place
    lcd.setCursor(6, 1); // position 6, second row
    lcd.print("Fahrenheit");
  // print to serial monitor
  Serial.print("Raw average = ");
  Serial.print(total / numReadings);
    Serial.println("  ----too hot----");
  else {
    Serial.print("   The temperature is  ");
    Serial.print(tempC, 2);
    Serial.print(" Celcius  ");
    Serial.print(tempF, 1);
    Serial.println(" Fahrenheit");
  delay(1000); // use a non-blocking delay when combined with other code
Wawa,
Thanks for your help, it worked perfectly.
