TMP36 Reading High (Arduino YUN)
I have a simple project to read the temperature and send it to a camera to display in the image. All works from a technical point of view, but the temperature seems 10F degrees too high, like 80F when it's 70F.
I measure the voltage at the tmp36 sensor and it's reading about 3/4 V and when I do a getVoltage(0) it reads .76 to .77. I've tried different formulas and come to the same conclusion, .765 or about 80F using commonly available formulas.
What I've tried so far:
  1. 2 different sensors from 2 different suppliers, both read the same
  2. bread boarding vs. solder, both read the same
  3. 5V and 3.3V on the board, the board voltage is correct, but results from the center pin are the same .76 to .77
  4. 0.1uF Cap between ground and volts, same results
  5. 0.01iF Cap between center pin and ground, same results
  6. putting sensor in ice water - lowered temp to 44F
  7. putting sensor between fingers - raised temp to about 90F
I plugged it in outside sending temps via WiFi, same results.
