Hi Guys, I am currently working on a project where the following is my goal:
It should be able to record sth with a mic, save as .wav to a SD card and then saving the information (folder number and title number) on a mifare classic tag to make the tag. Everything by its own has worked so far and has been tested, the recording and (afterwards) scanning of the tag is giving me a great headache.
The problem is that the .wav files become corrupted (0 Bytes) when "using" the scanNFCTag() method (see bold in code). Using here does not mean that I enter the method, even if i do not scan a card, the file gets corrupted, whereas if I comment the method out (or delete the line) the file is saved correctly.
I am using a RFID-RC522 and SD Card Adapter HW 125. I am native Java programmer, so I have some difficulties with C++ but code-wise I do not see any problem.
Thanks in advance for any help! Thanks a lot!
#include <Wire.h>
#include <SPI.h>
#include <MFRC522.h>
#include <SD.h>
#include <TMRpcm.h>
#define SS_PIN 10
#define RST_PIN 9
#include "Arduino.h"
/* Create an instance of MFRC522 */
MFRC522 mfrc522(SS_PIN, RST_PIN);
/* Create an instance of MIFARE_Key */
MFRC522::MIFARE_Key key;
/* Set the block to which we want to write data */
/* Be aware of Sector Trailer Blocks */
int blockNum = 2;
/* Create an array of 16 Bytes and fill it with data */
/* This is the actual data which is going to be written into the card */
byte blockData [16] = {"Folder1Title1"};
/* Create another array to read data from Block */
/* Legthn of buffer should be 2 Bytes more than the size of Block (16 Bytes) */
byte bufferLen = 18;
byte readBlockData[18];
char whatWasRead[18];
int folderNumber, titleNumber;
const int folderPosition = 6;
const int titlePosition = 12;
int currentTime = 0;
int previousTime = 0;
const int period = 1000;
MFRC522::StatusCode status;
int LED = 3;
int TASTER = 2;
int tasterstatus = 0;
bool executedOnce = false;
File myFile;
String fileName = "01/001.wav";
bool startedRecording = false;
bool readyToScan = false;
TMRpcm audio;
digitalWrite(10, HIGH);
digitalWrite(5, HIGH);
mfrc522.PCD_Init();
Serial.print("Initializing SD card...");
if (!SD.begin(5)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
if (!SD.exists("/01")) {
SD.mkdir("01");
/* Prepare the ksy for authentication */
/* All keys are set to FFFFFFFFFFFFh at chip delivery from the factory */
for (byte i = 0; i < 6; i++)
key.keyByte[i] = 0xFF;
tasterstatus = digitalRead(TASTER);
//record here
if (tasterstatus == HIGH) {
if (!startedRecording) {
digitalWrite(5, LOW);
Serial.println(F("Starting to record"));
// with bitrate of 4000 the cracklign in the BG is takable
audio.startRecording("01/001.wav", 4000, A1);
startedRecording = true;
// put LED on
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
if (startedRecording && !executedOnce) {
//Serial.print(startedRecording);
Serial.println(F("stop to record"));
audio.stopRecording("01/001.wav");
delay(2000);
// scan card here
executedOnce = true;
readyToScan = true;
if (readyToScan) {
Serial.println(F("scan now!"));
int Time = millis();
digitalWrite(10, LOW);
while (millis() < Time + 7000) {
if (!mfrc522.PICC_IsNewCardPresent() || ! mfrc522.PICC_ReadCardSerial()) {
Serial.print(F("."));
Serial.println(F(""));
Serial.println(F("Found Card!"));
**scanNFCTag();**
delay(100);
Serial.println(" ");
Serial.println("No Scanning anymore");
// Halt PICC
mfrc522.PICC_HaltA();
// Stop encryption on PCD
mfrc522.PCD_StopCrypto1();
void scanNFCTag() {
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i], HEX);
Serial.print(" ");
Serial.print("\n");
Serial.println(F("Writing to Data Block..."));
WriteDataToBlock(blockNum, blockData);
Serial.print("\n");
Serial.println(F("Reading from Data Block..."));
ReadDataFromBlock(blockNum, readBlockData);
Serial.print("\n");
Serial.print(F("Data in Block:"));
Serial.print(blockNum);
Serial.print(" --> ");
for (int j = 0 ; j < 16 ; j++)
Serial.write(readBlockData[j]);
whatWasRead[j] = (char)readBlockData[j];
Serial.print("\n");
Serial.print(F("What was read: "));
Serial.println(whatWasRead);
folderNumber = whatWasRead[folderPosition] - '0';
titleNumber = whatWasRead[titlePosition] - '0';
Serial.print(F("folder number: "));
Serial.println(folderNumber);
Serial.print(F("title number: "));
Serial.println(titleNumber);
void WriteDataToBlock(int blockNum, byte blockData[])
/* Authenticating the desired data block for write access using Key A */
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, blockNum, &key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK)
Serial.print(F("Authentication failed for Write: "));
Serial.println(mfrc522.GetStatusCodeName(status));
return;
Serial.println(F("Authentication success"));
/* Write data to the block */
status = mfrc522.MIFARE_Write(blockNum, blockData, 16);
Serial.print(F("Writing to Block failed: "));
return;
Serial.println(F("Data was written into Block successfully"));
void ReadDataFromBlock(int blockNum, byte readBlockData[])
/* Authenticating the desired data block for Read access using Key A */
byte status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, blockNum, &key, &(mfrc522.uid));
Serial.print(F("Authentication failed for Read: "));
return;
/* Reading data from the Block */
status = mfrc522.MIFARE_Read(blockNum, readBlockData, &bufferLen);
Serial.print("Reading failed: ");
return;
Serial.println(F("Block was read successfully"));
```**fett gedruckter Text**
