I have my code uploaed onto the Chip all working fine.
I want to migrate the chip to a breadboard, i dont want to change the code at all.
Do i just follow this step up untill ARDUINO READY?
Can i just USE
5V REG - CAPS
CRYSTAL
CAPS
RESISTOR
I dont need to upload anymore code or check leds ect ect
-22 AWG wire
-7805 Voltage regulator
-2 LEDs
-2 220 Ohm resistors
-1 10k Ohm resistor
-2 10 uF capacitors
-16 MHz clock crystal
-2 22 pF capacitors
-small momentary normally open ("off") button, i.e. Omron type B3F
Anyone??
Yes, just go ahead to try it. it should work.
