To generate 2MHz frequency from aurdino due
hello everyone
I am getting errors while compiling,
please do help me out with it
code
const int freqOutputPin =3;
const int prescale  = 1;
const int ocr2bval  = 3;
const float period    = 2.0 * prescale * (ocr2bval+1) / (F_CPU/1.0e6);
const float freq      = 1.0e6 / period;
    pinMode(freqOutputPin, OUTPUT);
    TCCR2A = ((1 << WGM21) | (1 << COM2A0));
    TCCR2B = (1 << CS20);  // No prescale
    TIMSK2 = 0;
    OCR2B = ocr2bval;
    Serial.print("Period    = ");
    Serial.print(period);
    Serial.println(" microseconds");
    Serial.print("Frequency = ");
    Serial.print(freq);
    Serial.println(" Hz");
You seem to have code that was written for an AVR micro like an UNO or a Mega and want it to run as is on a SAM board like a Due. Ain't gonna happen. You need to scrap this whole code and look for something specific to the Due.
yea i know
but i am very new to Arudino due
so can you help me out how to move on with it?
How does that make you incapable of using a basic search engine? Google "generate square wave from Due" or something like that. I'm positive that this has been solved several times over. Come back when you have some specific question that is better than, " I've got nothing, I've done nothing, you explain the whole entire thing to me here."
yea i understand
but can you tell me the code how to write
i ain't getting it
thank you
No. This isn't a free code writing service. This is where you get help fixing the code you write. If you want someone to write it for you then there are folks that will do that for hire in the Gigs and Collaborations section. Just be very very specific about the requirements and how much you are willing to pay.
Hi mark07,
The following code uses the Due's PWM controller to output a 2MHz square wave on pin DAC1:
// Output a 2MHz PWM waveform at a resolution of 5-bits on pin DAC1 (PWML0)
  // PWM Set-up on pin: DAC1
  REG_PMC_PCER1 |= PMC_PCER1_PID36;                     // Enable PWM
  REG_PIOB_ABSR |= PIO_ABSR_P16;                        // Set PWM pin perhipheral type A or B, in this case B
  REG_PIOB_PDR |= PIO_PDR_P16;                          // Set PWM pin to an output
  REG_PWM_CLK = PWM_CLK_PREA(0) | PWM_CLK_DIVA(1);      // Set the PWM clock rate to 84MHz (84MHz/1)
  REG_PWM_CMR0 = PWM_CMR_CPRE_CLKA;                     // Enable single slope PWM and set the clock source as CLKA
  REG_PWM_CPRD0 = 42;                                   // Set the PWM frequency 84MHz/2MHz = 42
  REG_PWM_CDTY0 = 21;                                   // Set the PWM duty cycle 50%
  REG_PWM_ENA = PWM_ENA_CHID0;                          // Enable the PWM channel
void loop() {}
If you need to alter the duty cycle to a value other than 50% during operation then change the REG_PWM_CDTYUPD0 (duty cycle update register for channel 0) to a value between 0 and 42, (the value in the period register (REG_PWM_CPRD0).
The PWM controller has 8 channels, so it's also possible assign other pins if necessary, see Arduino Due 10 bit muti-channel center aligned PWM at 2000 Hz - Arduino Due - Arduino Forum.
