To get value from keypad
Hello everyone!
I have a question. What syntax do i use to tell the compiler to read the input from a keypad.
For example, we have Serial.available() syntax to read the input from serial monitor. Because in my function i would like to tell the compiler to not run this program until there’s keypad input.
Thanks in advance!
How is the keypad connected to the Arduino?
assuming you use the keypad library
this is how you see if a key is pressed
char key = keypad.getKey();
  if (key != NO_KEY ){
   // a key was pressed
    Serial.println(key);
so to your question, have at the start of your setup()
  while (keypad.getKey() == NO_KEY); // wait until a key press
