to link a client connection to an interrupt
Hi to all,
I have a doubt about running a "web server" process on Arduino.
I read that with this line code Arduino is listening for incoming clients.
// listen for incoming clients
  Client client = server.available();
What happen if Arduino is busy in a measurement during a client connection?
Is client connection lost?
Is it possible to link a client connection to an interrupt??
you have to look at the whole code
  // if an incoming client connects, there will be bytes available to read:
  if (client == true) {
    // read bytes from the incoming client and write them back
    // to any clients connected to the server:
    server.write(client.read());
  // you can do your measurements here
Server.available() is non blocking (it does not wait for a connection) so it will return with a socket nr ( some value > 0 ) which is interpreted as true, or with 0 interpreted as false.
See - Ethernet - Arduino Reference -
robtillaart:
Hi robtillart,
thank you for your reply.
Yes, i saw that code and I had understood that Server.available() was a non blocking instruction.
In fact, my question was different.
What happen if i write a code that required "a lot of time" and Arduino can't execute Server.available() in time?
For example, i write a function that must read some values from different sensors. A client send a message to webserver on Arduino while this are measuring.
How can I interrupt measurement for managing client request?
thanks
Then you will not get a connection ...
Arduino is only single threaded, so you cannot have a background process waiting for a network connection. Interrupts is no solution imho as interrupts should be as short as possible.
robtillaart:
You are right.
If Arduino is single threaded, how does the library support up to four concurrent connection (incoming or outgoing or a combination)?
The chip in the ethernet shield does, and in the lib reflects that administratively.
