To understand this small Lifi code
:slight_smile: Hello people...I wanted to understand implementation of LiFi for transmiting text and came across this working code that I could not understand very well.
As I am new to arduino language and want to make myself better in it...
plz give functions of each line to make me understand this code...it will be appreciated very much...
////////////////////transmiter code/////////////////
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
// Clear Timer on Compare Match (CTC) Mode
bitWrite(TCCR1A, WGM10, 0);
bitWrite(TCCR1A, WGM11, 0);
bitWrite(TCCR1B, WGM12, 1);
bitWrite(TCCR1B, WGM13, 0);
// Toggle OC1A and OC1B on Compare Match.
bitWrite(TCCR1A, COM1A0, 1);
bitWrite(TCCR1A, COM1A1, 0);
bitWrite(TCCR1A, COM1B0, 1);
bitWrite(TCCR1A, COM1B1, 0);
// No prescaling
bitWrite(TCCR1B, CS10, 1);
bitWrite(TCCR1B, CS11, 0);
bitWrite(TCCR1B, CS12, 0);
OCR1A = 210;
OCR1B = 210;
Serial.begin(2400);
Serial.println("testing testing testing");
////////////////////reciever code/////////////////
Serial.begin(2400);
pinMode(13, OUTPUT);
// if incoming serial
if (Serial.available()) {
readSerial();
digitalWrite(13, HIGH);
else {
digitalWrite(13, LOW);
void readSerial() {
char val = Serial.read();
Serial.print(val);
Post a link to the tutorial page where you found this. There must be instruction on how to connect the leds / IR receiver circuit.
The bitWrite() statements are setting up a timer to put a pulse on the pins which modulates the transmitter led which presumably you have to connect somehow between TX and pin 9
