to use interrupt as a counter while low power
hi;
i want to use interrupts as a counter, here my codes;
#include <SPI.h>
#include <RF24.h>
#include "LowPower.h"
#define CE 7
#define CSN 8
volatile bool counting = true;
volatile unsigned long events;
unsigned long startTime;
const unsigned long INTERVAL = 1000;  // 1 second
const uint64_t ad = 0xE8E8F0F0E1LL;
RF24 radio(CE, CSN);
    pinMode(8, OUTPUT);
    pinMode(7, OUTPUT);
    radio.begin();
    radio.setChannel(108);
    radio.setDataRate(RF24_250KBPS);
    radio.setPALevel(RF24_PA_MIN);
    radio.openWritingPipe(ad);
    attachInterrupt(digitalPinToInterrupt(2), eventISR, FALLING);
void eventISR() {
  if (counting) events++;
void SendToServer() {
  int _tmp = events;
  Serial.print("Sending... ");
  //sprintf(msg, "%ld", events);
  radio.write(&_tmp, sizeof(_tmp));
  Serial.println(events);
  LowPower.powerDown(SLEEP_1S, ADC_OFF, BOD_OFF);
  if (counting) {
    counting = false;
    SendToServer();
  noInterrupts ();
  events = 0;
  startTime = millis ();
  EIFR = bit (INTF0);  // clear flag for interrupt 0
  counting = true;
  interrupts ();
void loop2() {
  if (counting) {
    if (millis () - startTime < INTERVAL) return;
    counting = false;
    SendToServer();
  noInterrupts ();
  events = 0;
  counting = true;
  interrupts ();
“void loop2()” works perfect. serial output like;
Sending… 0
Sending… 0
Sending… 0
Sending… 10
Sending… 20
but when i use “void loop()”, serial output like;
Sending… j
Sending… j
Sending… j
Sending… j
Sending… j
what is this “j” anyway.
so, just like i sad, i want to use interrupts as a counter while low power. If this is not possible, what would you recommend for low-power counter. I want to run this project with battery.
You have three things going on - interrupts from some undefined source triggering an ISR, a radio being used to send data, and narcolepsy.
Get rid of TWO of them, until you are sure that the other one works.
  int _tmp = events;
Does THAT make any sense?
Hi;
Thank you, i will try this.
I have another question about using interrupts while low power. I assume that external interrupts always wake up arduino right?
Wrong. Some kinds of external interrupts will wake a sleeping Arduino, not all kinds, from some levels of sleep. You'd have to test whether your type of external interrupt wakes your Arduino from your sleep level.
