TOF10120 cannot read far distance
Hello,
I have two tof10120 each connected to an arduino nano via i2c. One of them will only read distances of 208mm or shorter. If there's nothing infront, it will still read 208mm. The other sensor works fine with longer distances and reads higher values.
What could be causing such an issue?
Below is the code I have been using on both Arduinos to read and output the distance to Serial Monitor.
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
int x_mm; // distance in millimeters
unsigned short lenth_val = 0;
unsigned char i2c_rx_buf[16];
  Wire.begin();
  x_mm = ReadDistance();
  Serial.println(x_mm);
  delay(50);
void SensorRead(unsigned char addr,unsigned char* datbuf,unsigned char cnt)
  unsigned short result=0;
  // step 1: instruct sensor to read echoes
  Wire.beginTransmission(82); // transmit to device #82 (0x52), you can also find this address using the i2c_scanner code, which is available on electroniclinic.com
  // the address specified in the datasheet is 164 (0xa4)
  // but i2c adressing uses the high 7 bits so it's 82
  Wire.write(byte(addr));      // sets distance data address (addr)
  Wire.endTransmission();      // stop transmitting
  // step 2: wait for readings to happen
  delay(1);                   // datasheet suggests at least 30uS
  // step 3: request reading from sensor
  Wire.requestFrom(82, cnt);    // request cnt bytes from slave device #82 (0x52)
  // step 5: receive reading from sensor
  if (cnt <= Wire.available()) { // if two bytes were received
    *datbuf++ = Wire.read();  // receive high byte (overwrites previous reading)
    *datbuf++ = Wire.read(); // receive low byte as lower 8 bits
int ReadDistance(){
    SensorRead(0x00,i2c_rx_buf,2);
    lenth_val=i2c_rx_buf[0];
    lenth_val=lenth_val<<8;
    lenth_val|=i2c_rx_buf[1];
    delay(10);
    return lenth_val;
