int lastState=0,p=0,status,q;
status=digitalRead(2);
if(status==p){
display(lastState);
if (status!=p){
lastState=lastState++;
status=p;
I want to check the condition while switch thatone is connected in IO2 pin, pressed the display function work but if condition is going wrong when i release swich it increse the lastState variable continuously, but i want to increase it at once when switch is toggle.
please help me frnds....
is compiler dependent and definitely NOT recommended. I do not know what the gcc compiler used by the Arduino IDE does with this construct.
Instead, do this:
lastState++;
You want to do something when the switch state BECOMES something rather than when the switch state IS something. There is a state change detection example that demonstrates how to do this.
johnwasser:
The "if (status!=p)" part will never be true because you put it INSIDE the "if (status==p)".
If you edit your code in the ide so that each { and } is on a line of its own, then hit ctrl-T, it will format with nice indentation as below, and it's easy to see what johnwasser is saying.
pinMode(2, INPUT_PULLUP);
int lastState = 0, p = 0, status, q;
status = digitalRead(2);
if (status == p)
display(lastState);
if (status != p)
lastState = lastState++;
status = p;
