Toggle Button Activated Program
Hi all,
I'm having issues coding a toggle button activated program such that when I hit the button, it'll initiate the programs, and when I hit it again, it'll stop the program. With my current code, I have to hold down the button a half a second, and then it'll run the program once and then stop. Any suggestions/fixes to this issue? I have attached the fritzing diagram.
Thank you.
int speedPin1=4;
int speedPin2=5;
int dir1=3;
int dir2=2;
int dir3=6;
int dir4=7;
int speed;
//For DC Motors
int trigPin = 8;
int echoPin = 9;
long distance;
// For Ultrasonic Sensor
int buttonPin=13;
int buttonNew;
int buttonOld=1;
int State=0;
// For Button
pinMode(speedPin1,OUTPUT);
pinMode(speedPin2,OUTPUT);
pinMode(dir1,OUTPUT);
pinMode(dir2,OUTPUT);
pinMode(dir3,OUTPUT);
pinMode(dir4,OUTPUT);
//For DC Motors
//3 seconds for 360 turn
pinMode(trigPin, OUTPUT);
digitalWrite (trigPin, LOW);
pinMode(echoPin, INPUT);
//For Ultrasonic Sensor
pinMode(buttonPin, INPUT);
//For button
void Forward() {
Serial.println("Forward");
digitalWrite(dir1,LOW);
digitalWrite(dir2,HIGH);
digitalWrite(dir3,HIGH);
digitalWrite(dir4,LOW);
//Robot will go Forward
void Reverse() {
Serial.println("Reverse");
digitalWrite(dir1,HIGH);
digitalWrite(dir2,LOW);
digitalWrite(dir3,LOW);
digitalWrite(dir4,HIGH);
//Robot will Reverse
void TurnLeft() {
Serial.println("TurnLeft");
//Robot will turn left
void TurnRight() {
Serial.println("TurnRight");
//Robot will turn right
void Stop() {
Serial.println("Stop");
//Robot will stop
void Distance (){
digitalWrite(trigPin, LOW);
delayMicroseconds(10);
digitalWrite(trigPin, HIGH);
Serial.print ("Distance: ");
distance = pulseIn(echoPin, HIGH) * 0.034 / 2.0;
delay(200);
if (distance >= 150){
  Serial.println("Out of Range");
  Stop();
  TurnLeft();
  delay(random(500,2100));
  TurnRight();
  delay(random(100,1500));
  Stop();
  Forward();
else {
  Serial.print (distance);
  Serial.println ("cm");
//Reads distance. If/else statement sets maximum distance
void Avoid (){
  if (distance < 15)
// distance can be between 45 or 60 to avoid obstacle correctly at an angle
Stop();
delay(10000);
Reverse();
delay(random(1000,3000));
TurnRight();
//avoidance program
buttonNew=digitalRead(buttonPin);
if(buttonOld==0 && buttonNew==1){
if (State==0){
Serial.println("ON");
Distance();
Avoid ();
Forward();
State=1;
else {
Serial.println("OFF");
delay(2000);
Stop();
State=0;
buttonOld=buttonNew;
delay(100);
test_2.ino (2.54 KB)
If you post your code as described in the forum guidelines more members will see your code.
Delays block execution and make the program unresponsive. Non-blocking timing tutorials:
Several things at a time.
Beginner's guide to millis().
Blink without delay().
Your button has no pullup resistor so its input pin is floating when the button is not pressed. Enable the internal pullup with pinMode(pin, INPUT_PULLUP).
The state change detection example may help with the button toggling a state. See also state change with active low button.
You can take a look to How to use button to start/stop program
