Toggle Button Timeout Using Millis()
Hello,
Please pardon my newbie level and my question that may seem trivial. I am completely new to this business, and I have been searching for over a week for an answer to my question, with no luck.
I am building a program for a specific project, which controls multiple window rolling shutters. My goal to to set 4 buttons per rolling shutter, where two are momentary up and down (where as long as I am holding the button(s), the shutters are rolling), and the other two are toggle up and down (where I push once and release, then the corresponding shutter will roll up or down for a specific period of time).
I was successful building the sketch, but I am unable to use millis() function for the toggle switches. When I use delay(), it works as intended, but it blocks the micro-controller from controlling other variables. Thus, I know I have to use millis()
What I am particularly interested in, is program the toggle button to run the corresponding if statement for a specified period of time (1000ms) using millis().
Here is my sketch (primitive, I know ... but I am trying to learn as much as I could ... I certainly appreciate any help, advice, or guidance)
int relay1 = 0;
int relay2 = 1;
int relay3 = 2;
int relay4 = 3;
int button1 = 4;
int togglebutton1 = 5;
int button2 = 6;
int togglebutton2 = 7;
 pinMode(relay1, OUTPUT);
 pinMode(relay2, OUTPUT);
 pinMode(relay3, OUTPUT);
 pinMode(relay4, OUTPUT);
 pinMode (button1, INPUT_PULLUP);
 pinMode (togglebutton1, INPUT_PULLUP);
 pinMode (button2, INPUT_PULLUP);
 pinMode (togglebutton2, INPUT_PULLUP);
 if ((digitalRead(button1) == LOW)) {
   digitalWrite(relay1, LOW);
   digitalWrite(relay2, LOW);
 if ((digitalRead(togglebutton1) == LOW)) {
   delay(10000);
 if
 ((digitalRead(button2) == LOW)) {
   digitalWrite(relay3, LOW);
   digitalWrite(relay4, LOW);
 if ((digitalRead(togglebutton2) == LOW)) {
   delay(10000);
 else {
   digitalWrite(relay1, HIGH);
   digitalWrite(relay2, HIGH);
   digitalWrite(relay3, HIGH);
   digitalWrite(relay4, HIGH);
Please edit your post and add
** **[code]** **
before your code and
** **[/code]** **
after your code. So it looks like below; that makes is easier to read and copy.
your code here
Have you read and understood Using millis() for timing. A beginners guide ?
Here's some example code using millis() for run time out after the togglebutton press.
Your code is perhaps best rewritten as a state machine, but I have used your conditional logic structure and added boolean control variables to the "if" conditional statements.
There are control variables and timing variables to start/finish the time out period after a togglebutton press. There are also control variables to turn the relays off when the untimed buttons are released. You cannot do the untimed turn offs with a simple "else" conditions because relays 1 and 2 are controlled by all 4 buttons.
I used the indicator led on pin 13 to help show the timing.
int relay1 = 0;
int relay2 = 1;
int relay3 = 2;
int relay4 = 3;
int button1 = 4;
int button2 = 6;
//variables to control state and timeout after toggle button press
unsigned long currentTime;
unsigned long startTime1;
unsigned long startTime2;
boolean timing1 = false;
boolean timing2 = false;
unsigned long runTime1 = 10000;
unsigned long runTime2 = 10000;
//variables to control on/off after button press and hold
boolean holding1 = false;
boolean holding2 = false;
  //Test led for timing check
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  currentTime = millis();
  if ((digitalRead(button1) == LOW) && (holding1 == false)) //button1 pressed
    digitalWrite (13, LOW);
    holding1 = true;
  if (holding1 == true && digitalRead(button1) == HIGH) //button1 released
    digitalWrite (13, HIGH);
    holding1 = false;
  if ((digitalRead(togglebutton1) == LOW) && (timing1 == false) ) //togglebutton1 pressed
    digitalWrite(13, LOW);
    timing1 = true;
    startTime1 = currentTime;
    // delay(10000);
  if (timing1 == true && (currentTime - startTime1 >= runTime1))//togglebutton1 timed out
    timing1 = false;
  if ((digitalRead(button2) == LOW) && (holding2 == false)) //button2 pressed
    holding2 = true;
  if ((digitalRead(button2) == HIGH) && (holding2 == true)) //button2 released
    holding2 = false;
  if ((digitalRead(togglebutton2) == LOW) && (timing2 == false)) //togglebutton2 pressed
    timing2 = true;
    startTime2 = currentTime;
    //delay(10000);
  if (timing2 == true && (currentTime - startTime2 >= runTime2))//togglebutton2 timed out
    timing2 = false;
UKHeliBob:
Thank you for referring me to this document. I did read it and I learned a lot about millis(). I do appreciate directing me into the right direction
sterretje:
 before your code and  after your code. So it looks like below; that makes is easier to read and copy.
Thank you for this wonderful trick, I was wondering how to include the sketch into an easier to scroll and copy format. I have updated my script.
cattledog:
int relay1 = 0;
int relay2 = 1;
int relay3 = 2;
int relay4 = 3;
int button1 = 4;
int button2 = 6;
    holding1 = true;
    holding1 = false;
    timing1 = true;
    // delay(10000);
    timing1 = false;
    holding2 = true;
    holding2 = false;
    timing2 = true;
    //delay(10000);
    timing2 = false;
This is very helpful, I am so thankful for you and for your time and effort helping me out. While this code works perfect for the toggle switch and momentary switch, I ran into another problem. The toggle switch in my case is NOT a physical momentay switch, but rather is a relay itself. Here is the situation: I am adding a LUTRON Wireless light switch where I can control from a dedicated app the system. I am planning to use a 120V coil relay connected to the lutron wireless light switch, and use the normally open and the normally closed sides of that relay as my toggle buttons for the UP and DOWN. when I turn the wireless switch on, it would trigger the attached relay, thus closing the toggle circuit, initiating the toggle the Roller UP function, when I turn the wireless off, the relay will set back to the other position, where it will also toggle the ROLLER DOWN function.
The problem that I am running into, is how to make the toggle part of the sketch expire and not continuously run when the toggle button or function is still pressed (a relay in the normal open position for roller up, or normal closed position for the roller down)?
In other words, I want the toggle button function to timeout in the specified interval even if the toggle button continues to be pushed....
too picky I am I guess .... My wife says that I am too OCD and crazy enough. I think she is right....
I think there is a simple modification to the code which will allow for an unconditional time out of the togglebuttons. By making the switch between timing = true and timing = false dependent upon the switch release, we can keep the code from reentry into the block which turns the relays on. Calling the variable timing is not quite accurate for its new function, but I can't quite think of a better name.
I thought there were some issues with switch bounce on togglebutton release with this new code, so I added some debounce delay and repeated readings.
See if this version does what you want.
int relay1 = 0;
int relay2 = 1;
int relay3 = 2;
int relay4 = 3;
int button1 = 4;
int button2 = 6;
unsigned long runTime1 = 5000;
unsigned long runTime2 = 5000;
    holding1 = true;
    holding1 = false;
    timing1 = true;
    if (digitalRead(togglebutton1) == HIGH) //button was released
      delay(50);//debounce delay
      if (digitalRead(togglebutton1) == HIGH) //reading is solid
        timing1 = false; //reenables the togglebutton1
    holding2 = true;
    holding2 = false;
    timing2 = true;
    if (digitalRead(togglebutton2) == HIGH) //button was released
      if (digitalRead(togglebutton2) == HIGH) //reading is solid
        timing2 = false; //reenables the togglebutton2
cattledog:
Thank you :wink:
By the way: Did you see my PM to you on May 28th? There is something that I would love if you consider.
the sketch is better and getting closer to what I intended it to be. However, I ran into another smaller obstacle (those obstacles seems to become smaller and smaller as I explore and talk to great people like you over the forum).
When ''togglebutton1'' is activated and held in activation, (via a relay in my case), it expires according to the interval specified, but it won't be able to execute an input from ''button1'' as long as the
''togglebutton1'' is activated. However, it will still be able to execute the if statement associated with ''button2'', and ''togglebutton2''. On the other hand, when ''togglebutton2'' is activated and held in position (due to the same relay set back to the other NO or NC status), it still expires after the specified time, and it will accept "togglebutton1" input only , but it WILL NOT execute "button1" or "button2" input during the hold. I spent like 2 hours of trial and error but without luck. Obviously I am missing the solid fundamentals of arduino, because my exposure is so little.
what I am trying to achieve, is, if the roller shutters were put all the way up or all the way down using the relay as trigger to "toggglebutton1" or "togglebutton2", to still be controllable either way using the momentary up or down buttons, without the toggle relay being disconnected. I wanted to make "button1", and "button2" responsive all the time, regardless of whether "toggle1" or "toggle2" activation status is.
I am amazed and humbled for the amount of knowledge and truth out there, and moreover, to the level of Karma and kindness some people have to offer. Thank you again.
I think I understand your requirements, I think they are best met by restructuring the program to work on button state transitions where a button becomes pressed or become released rather than the button state (pressed or released) with a lot of logical conditions pasted on. You should be able to work the press and hold button independently of the timeout toggle button. Give me a day or so to work on this.
I see something like this
if button1 becomes pressed turn stuff on
if button1 becomes released turn stuff off
if togglebutton1 becomes pressed turn stuff on with timeout
if togglebutton1 becomes released do nothing
I'm not certain about the need for debounce, but I will probably use a button library (Bounce2) which simplifies reading the debounced transitions.
You could use a library like TDuino for convenience:
#include <TDuino.h>
#define BUTTON1 4
#define TOGGLE1 5
#define BUTTON2 6
#define TOGGLE2 7
#define RELAY1 0
#define RELAY2 1
#define RELAY3 2
#define RELAY4 3
#define TOGGLE_TIMEOUT 10000
void timerCallback(byte timerId);
TButton btn1(BUTTON1), btn2(BUTTON2);
TButton tgl1(TOGGLE1), tgl2(TOGGLE2);
TTimer timer(timerCallback, 2);
void setRelays(byte state, bool all)
  digitalWrite(RELAY1, state);
  digitalWrite(RELAY2, state);
  if (all)
    digitalWrite(RELAY3, state);
    digitalWrite(RELAY4, state);
void buttonPress(byte pin, int state)
  if (pin == BUTTON1) setRelays(LOW, false);
  else if (pin == TOGGLE1)
    timer.set(0, TOGGLE_TIMEOUT, 1);
  else if (pin == BUTTON2) setRelays(LOW, true);
  else if (pin == TOGGLE2)
    timer.set(1, TOGGLE_TIMEOUT, 1);
void buttonRelease(byte pin, int state)
  setRelays(HIGH, pin == BUTTON2);
  setRelays(HIGH, timerId == 1);
  btn1.setup();
  btn2.setup();
  tgl1.setup();
  tgl2.setup();
  timer.setup();
  btn1.onPress(buttonPress);
  btn2.onPress(buttonPress);
  tgl1.onPress(buttonPress);
  tgl2.onPress(buttonPress);
  btn1.onRelease(buttonRelease);
  btn2.onRelease(buttonRelease);
  //tgl1.onRelease(buttonRelease);
  //tgl2.onRelease(buttonRelease);
  pinMode(RELAY1, OUTPUT);
  pinMode(RELAY2, OUTPUT);
  pinMode(RELAY3, OUTPUT);
  pinMode(RELAY4, OUTPUT);
  btn1.loop();
  btn2.loop();
  tgl1.loop();
  tgl2.loop();
  timer.loop();
Code is untested and may not work at all :slight_smile:
EDIT: Code simplified…
Here is the state change version of the code using the Bounce2 library for debounced button transitions. The library is available through the library manager. The press and hold buttons work when the toggle buttons have timed out.
I’m sure the code can be tidied up with use of arrays.
byte relay1 = 0;
byte relay2 = 1;
byte relay3 = 2;
byte relay4 = 3;
byte button_1 = 4;
byte togglebutton_1 = 5;
byte button_2 = 6;
byte togglebutton_2 = 7;
#include <Bounce2.h> //available through ide library manager
//create 4 Bounce objects
Bounce button1 = Bounce();
Bounce togglebutton1 = Bounce();
Bounce button2 = Bounce();
Bounce togglebutton2 = Bounce();
  //Test led for timing check of relay outputs
  //set up button pin Bounce objects
  pinMode (button_1, INPUT_PULLUP);
  button1.attach(button_1);
  button1.interval(50);//debounce interval
  pinMode (togglebutton_1, INPUT_PULLUP);
  togglebutton1.attach(togglebutton_1);
  togglebutton1.interval(50);//debounce interval
  pinMode (button_2, INPUT_PULLUP);
  button2.attach(button_2);
  button2.interval(50);//debounce interval
  pinMode (togglebutton_2, INPUT_PULLUP);
  togglebutton2.attach(togglebutton_2 );
  togglebutton2.interval(50);//debounce interval
  //.update() key function of Bounce2 library that checks for debounced state of pins and any transitions
  button1.update();
  togglebutton1.update();
  button2.update();
  togglebutton2.update();
  if (button1.fell())//state change to pressed
  if (button1.rose())//state change to released
  if (togglebutton1.fell())
    timing1 = true;
    startTime1 = millis();
  if (timing1 == true && millis() - startTime1 >= runTime1) //togglebutton1 timed out
    timing1 = false;
  if (button2.fell())
  if (button2.rose())
  if (togglebutton2.fell())
    timing2 = true;
    startTime2 = millis();
  if (timing2 == true && millis() - startTime2 >= runTime2)
    timing2 = false;
cattledog:
I'm sure the code can be tidied up with use of arrays.
Gosh you are an artist! it worked exactly as I wanted it to work. You have relieved a long time agony and suffering... works flawlessly now! thank you thank you thank you :slight_smile: :slight_smile: :).
