Toggle button with timed on off help
There might still be holes in your description.
If a led is on, and the button is pressed (while the led is still on), should it advance to the next led ?
I wanted to see how many variables I would need when there are 4 blinking leds. It turns out that I need a many variables. Maybe too many :woozy_face:
This is not me knowing how to write this sketch. To be honest, I randomly threw in the code that I needed and then I moved around the code lines until it worked :face_with_raised_eyebrow:
#define NUM_LEDS 4
int ledPins[NUM_LEDS] = { 13, 12, 11, 10};
int currentLed = 0;                         // this is also the index to the array with pins
int ledState = LOW;                         // used the blink the active current led
bool ledActive;                             // is the led blinking and the timeout active ?
unsigned long timeStampButton = 0;          // remember moment of last button press
unsigned long previousMillisBlink;          // used to blink the led
const unsigned long timeOut = 2000UL;       // timeout for millis-timer
const unsigned long blinkInterval = 150UL;  // interval for blinking
const unsigned long debounceTime = 20UL;    // timing for debouncing
const int buttonPin = 2;                    // a button is connected to pin 2 and GND
int lastButtonState = HIGH;                 // idle high
  for( int i=0; i<NUM_LEDS; i++)
    pinMode( ledPins[i], OUTPUT);           // all the leds are outputs
  pinMode( buttonPin, INPUT_PULLUP);
  // Set initital state, turn first led on, start millis-timer
  currentLed = 0;
  timeStampButton = millis();
  ledActive = true;
  unsigned long currentMillis = millis();
  int buttonState = digitalRead( buttonPin);
  if( buttonState != lastButtonState && currentMillis - timeStampButton >= debounceTime)
    lastButtonState = buttonState;
    timeStampButton = currentMillis;        // timestamp of last valid button press
    if( buttonState == LOW)                 // low is active
      // The current led could be on
      if( ledActive && ledState == HIGH)
        digitalWrite( ledPins[currentLed], LOW);
      // advance to the next led
      currentLed++;
      if( currentLed >= NUM_LEDS)
        currentLed = 0;
      ledActive = true;
  if( ledActive)
    if( currentMillis - timeStampButton >= timeOut)
      // turn this led off
      ledActive = false;           // turn millis-timer off
    else if( currentMillis - previousMillisBlink >= blinkInterval)
      previousMillisBlink = currentMillis;
      ledState = ledState == HIGH ? LOW : HIGH;   // toggle led state
      digitalWrite( ledPins[currentLed], ledState);
Try this sketch in Wokwi simulation:
You should find you own way to make your own sketch. I hope that you see that I put the millis-timer in the main level of the loop() and the millis-timer runs on its own.
