Toggle buttons with while
Hello ! I have a question. I can only use while ( no if/ case / goto )
Therefore, If i have , say 4 push buttons , 1 start push button
An initial of digitalWrite(redled, HIGH);
and i am required to write a programe, for example to on a green led(but1 controls), blue led(but2 controls) , yellow led(but3 controls) and a pink led(but4 controls).
With only whiles , how do i do this? i am stuck with this
startvar=digitalRead(start);
While(startpushbutton==HIGH)
but1var=digitalRead(but1);
while(but1var==LOW) //
digitalWrite(greenled, HIGH);
but
Thanks in advance!
Hey!! sorry can I know what exactly you are trying to do ?
I mean as far as I understood this ...
button 1 will ON green led
button 2 will ON blue led
button 3 will ON yellow led
button 4 will ON pink led
then what is function of start push button ? red led ?
It's a strange requirement. Homework? Anyway, you can break from a while loop
If your code (using if) would be something like
if(digitalRead(btnRed) == HIGH)
  digitalWrite(redLed, HIGH);
if(digitalRead(btnGreen) == HIGH)
  digitalWrite(redGreen, HIGH);
You can change it to
while(digitalRead(btnRed) == HIGH)
while(digitalRead(btnGreen) == HIGH)
Even without the use of "break;" you can still use a 'while' in place of an 'if':
  // While the input is HIGH and the output is LOW
  while (digitalRead(start) == HIGH && digitalRead(redled) == LOW) {
    // Change the output to HIGH
  // While the input is LOW and the output is HIGH
 while (digitalRead(start) == LOW && digitalRead(redled) == HIGH) {
    // Change the output to LOW
    digitalWrite(redled, LOW);
johnwasser:
Nice. Thinking outside the box is an art :wink:
