i need a sample program for led to toggle, if i press a push button led must on and if i again press the same push button led must get off and wise versa. pls tel me the logic
raman00084:
You need to detect the time at which the switch goes from HIGH to LOW or LOW to HIGH. This is known as the the signal edge. The StateChangeDetection example demonstrates this. From there, toggling the LEDs is simple:
digitalWrite(ledPin, !digitalRead(ledPin));
How does this work if the ledPin is set as an output? You make the pin an output, to set the LED on/off and then(in that same line) your going to read the pin's state without changing its mode? How does that work.
If this is true, then why bother needing pinMode, if digitalWrite sets the pin as an output and digitalRead makes it an input.
HazardsMind:
You're not "making the pin an output" in this line of code. You're setting the bit in PORTX to either 1 or 0. Its a memory location (I think. It's memory mapped I/O, right?), so you can read it back.
... They don't. digitalWrite sets the bit and digitalRead returns the bit. pinMode is what affects the DDRX port.
raman00084:
You can try something like below:
//zoomkat LED button toggle test 11-08-2012
int button = 5; //button pin, connect to ground as button
int press = 0;
boolean toggle = true;
pinMode(13, OUTPUT); //LED on pin 13
pinMode(button, INPUT); //arduino monitor pin state
digitalWrite(5, HIGH); //enable pullups to make pin 5 high
press = digitalRead(button);
if (press == LOW)
if(toggle)
digitalWrite(13, HIGH); // set the LED on
toggle = !toggle;
digitalWrite(13, LOW); // set the LED off
toggle = !toggle;
delay(500); //delay for debounce
Ok, That makes more sense.
