Its current rating is only expressed in AC, is there a way I can calculate DC current rating with that info?
With my poor electronic knowledge I tried calculating R by law's ohm, then using that value for a DC voltage but result doesn't make sense so I guess is not that simple.
Jay98:
Thanks in advance.
Well, AC current is often measured or conveyed in 'RMS' format, which turns out to be an equivalent DC value for the case where the current really were DC. So..... at a first guess, can take that RMS rated AC current to be the same as the rated DC current. That's for starters maybe.
Well, it's a start but it's a bad start. As already pointed out, AC current crosses zero volts every 8 to 10 milliseconds for most power systems. DC has no such feature. Once the contacts begin to open with DC, there is nothing to extinguish any arc that forms. The result is contact destruction when there is enough energy in the source of said arc. If the DC source is regulating current, its game over as the voltage rises to maintain current.
Every switch is different. If there is no DC rating published, it's not DC rated. Simple.
Could you use a non-DC rated switch for DC? Sure, if the voltage and power is low enough. But what's low enough? Even 5 volts at an amp might be too much for some. There are no simplistic answers.
This was bothering me too so I just checked a few switches with multiple ratings:
2A @250VAC, 5A @120VAC, 5A @28VDC
15A @250VAC, 10A @24VDC, 15A @12VDC
6A @250VAC, 15A @ 28VDC
and there are some only single rated and with warnings in the manufacturer’s specs not to use for the wrong sort of electricity.
As you can see the numbers are all over the place. The good thing is that the specifications are usually available if you know the manufacturer but when buying from hobby suppliers it can be anyone’s guess.
How’s THIS for a misleading data sheet (or section of web page, whatever you want to call it)?:
At the top of the page it says 5a 125vac / 3a 250vac, so far so good. (625W and 750W respectively.)
Lower down it says Max current 5A, Max voltage 250VAC.
While those max values are actually correct, if you hadn’t seen the headline you would very likely assume the max current and max voltage went together (1250W), but they don’t.
Interestingly I don’t see any mention of VDC on that page, although most of the applications listed in point 6 there are likely to be DC.
MarkDerbyshire:
DC voltage ratings for switches and relays are usually 10% of the AC Voltage. ie a switch rated at 10A 250VAC will be 10A at 25VDC
That may be true but the whole point of a rating is that the maker says it can handle "this" or handle "that". When there's a fire and the opposing expert witness says "that switch maker didn't give a DC rating so it shouldn't have been used for DC at all", it's too late to remember this:
avr_fred:
I reckon it depends on situation. What specs have you got on that AC switch? (if you already have the switch, or if you're looking at a particular AC switch). And what level of DC current and what level of voltage is the switch going to encounter?
If in doubt, ask the manufacturers how they come up with a DC rating.
