toggling an output through on serial command.
Hello all! I have a ‘simple’ question. My programming skills are not very good so bare with me. I have written a program that will turn on 3 different output via serial command from terminal. It all works fine with if statements. However I want to use the same command to turn the input on and off. Right now one command is needed to turn on, and another to turn off.
#include <dht.h>
#include <LiquidCrystal.h>
int val;
int pump=51, fan=49, light=47;
const int rs = 45, en = 52, d4 = 50, d5 = 48, d6 = 46, d7 = 44;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
dht DHT;
#define DHT_PIN 53
pinMode(pump,OUTPUT);
pinMode(fan,OUTPUT);
pinMode(light, OUTPUT);
lcd.begin(16,2); //16 by 2 character display
} void loop()
{ val=Serial.read();
if(val==‘p’)
Serial.println(“PUMP ON”);
digitalWrite(pump,HIGH);
delay(6000);
digitalWrite(pump,LOW);
Serial.println(“PUMP Finished”);
if(val==‘f’)
Serial.println(“FAN ON”);
digitalWrite(fan,HIGH);
delay(3000);
digitalWrite(fan,LOW);
if(val==‘l’)
Serial.println(“LIGHT ON”);
digitalWrite(light,HIGH);
delay(100);
if(val==‘z’)
Serial.print("Humidity = ");
Serial.println(DHT.humidity);
Serial.print("Temp = ");
Serial.println(DHT.temperature);
Serial.print("Soil Moisture = ");
Serial.println(analogRead(0));
could somebody help me out with a possible nested if loop that toggles based on current output state? Everything I’ve tried has just made the program get stuck in one loop. Thanks in advance!
I suggest using struct to keep track of your pins and their status:
//declare struct
struct worker {
   int pin;
   bool enabled;
//declare struct objects and initialize
worker my_workers[3] = {{51, false}, {49, false}, {47, false}};
   //set pins to output
   for (int i=0; i<3; i++) {
      pinMode(my_workers[i].pin, OUTPUT);
   //get command
   //says 'f' will turn fan on and off
   if (val == 'f') {
      if (my_workers[1].enabled == false) {
         //the fan is not on
         //so turn it on here
         //set status to on
         my_workers[1].enabled = true;
         //the fan is on
         //turn it off here
         //set status to off
         my_workers[1].enabled = false;
arduino_new:
//declare struct
struct worker {
  int pin;
  bool enabled;
  //get command
  //says ‘f’ will turn fan on and off
  if (val == ‘f’) {
        //the fan is not on
        //set status to on
        //the fan is on
        //turn it off here
        //set status to off
This is very good advice, thanks for the help arduino_new! I will make a structure as you advised. I only need the light and fan to toggle. The water pump will only be run for a second or two and then turned off; can I leave the water pump out of the structure in that case?
I got it working by using your suggestion, thank you. :smiley:
Hi mike_drz
Any chance you can pop the completed sketch. I way newer at this then I should be. This function is mainly what I'm looking for but seem to be having trouble putting it all together!
Thanks
