void String2Morse()
len = code.length();
for (int i = 0; i < len; i++)
ch = code.charAt(i);
morse();
char MakeString()
if (pres_len < (unit_delay*3) && pres_len > 50)
return '.'; //if button press less than 0.6sec, it is a dot
else if (pres_len > (unit_delay*3))
return '-'; //if button press more than 0.6sec, it is a dash
void Morse_decod()
static String morse[] = {".-", "-...", "-.-.", "-..", ".", "..-.", "--.", "....",
int i = 0;
while (morse[i] != "!")
if (morse[i] == code)
Serial.print(char('a' + i));
Serial.print(" ");
i++;
if (morse[i] == "!")
Serial.println("");
Serial.println("This code is not exist!");
code = "";
void decoder() {
label:
while (digitalRead(but) == HIGH) {}
old_pres = rel_time;
pres_time = millis();
digitalWrite(led, HIGH);
while (digitalRead(but) == LOW) {}
rel_time = millis();
digitalWrite(led, LOW);
pres_len = rel_time - pres_time;
space = pres_time - old_pres;
if (pres_len > min_delay)
code += MakeString();
while ((millis() - rel_time) < (unit_delay * 3))
if (digitalRead(but) == LOW)
goto label;
Morse_decod();
void generator() {
while (Serial.available())
code = Serial.readString();
Serial.print(code);
Serial.print(" = ");
String2Morse();
Serial.println("");
int num = 0;
void project(){
if (digitalRead(button) == (HIGH))
num = 1 - num;
if(num)
decoder();
generator();
project();
if (digitalRead(button) == (HIGH)) {
mode();
project();
void mode() {
if (digitalRead(button) == (HIGH)){
delay(1000);}
else if (digitalRead(button) == (LOW)){
project();
Theres more to the code but I am not getting any error and the rest of the code is fine. The issue is solely in project(). I want to use generator() but then be able to switch to decoder() at the press of a button (button). The problem is that when I run this code I can use generator() but it doesnt switch to decoder() when I press a button. Once i press a button decoder() will only run after I use generator() again.
I have attached my code as well as my schematic though I dont think this problem extends to that. I may need to use interrupts but I dont know.
Example: I input 2 dots to output 'i' on screen. I then click another button (button) to switch. I input 'o' on my screen to output it as dots and dashes through decoder() but nothing happens. Once I input dots and dashes again using another button (but) it displays the translated word on the screen then it outputs 'o' from the previous step correctly.
MorseKey.ino (10 KB)
