Toggling pairs of leds
Hi.
I wonder if someone could point me in the right direction for this.
I have about 30 leds arranged in pairs of two. When one of the pair is turned on, the other should be turned off.
I think I have a couple of options in terms of general approach both of which would need an external supply for the leds and appropriate resistors
Use a nano and Multiplex using 4 * 74HC595 giving me control of upto 32 leds, turning each of the pair off or on programmatically.
Use a mega with transistors or mosfets with each of the 30 leds being controlled by its own digital pin.
However, I suspect that there must be an approach from the electronics side where I can use the same digital pin to switch the state of both of the pair of leds, Unfortunately, I just cant see it
Can anyone offer any advice or pointers as to how I can do this.
Thanks
60 LEDs? Mega2560 has 70 outputs.
Wire up each LED with its own resistor.
Make up two arrays, drive them high & low in pairs
for (x=0; x<30; x=x+1){
digitalWrite (array1[x], HIGH);
digitalWrite (array2[x], LOW);
delay(250);
digitalWrite (array2[x], HIGH);
digitalWrite (array1[x], LOW);
delay(250);
You can control two LEDs from one port pin if they're wired this way:
Sample code using pin three:
    pinMode( 3, OUTPUT );
    digitalWrite( 3, LOW );
    delay(250);
    digitalWrite( 3, HIGH );
    delay(250);
When the pin is HiZ (as when it's an input on power-up), both LEDs will be on. When the Arduino sets the pin to output, only one will be on. There's no way to turn the LEDs both off though...
Or use a MAX7219.
Leo..
