toInt() is not working properly
Hello.
I'm trying to get Arduino to print back values if they are integers with a value between 0 and 255.
The piece of code that checks whether the string from the serial port is an integer is the following:
bool checkStringIsNumerical(String myString)
    bool Isnum = false;
    uint16_t Numbers = 0;
    for (uint16_t i = 0; i < myString.length(); i++)
        if (myString[i] >= '0' && myString[i] <= '9')
            Numbers++;
    if (Numbers == myString.length())
        Isnum = true;
        Isnum = false;
    return Isnum;
I then call the previous function and check if the value is an integer and between 0 and 255 I print it back to the serial monitor:
if (checkStringIsNumerical(readString))
            if ((readString.toInt() >= 0) && (readString.toInt() <= 255))
              int pol = readString.toInt();
              Serial.println((String) "Input is : " + readString);
              Serial.println((String) "Numeric value is : " + pol);
              Serial.println("-------------------");
The problem: most of the time I get the correct value but sometimes I get a wrong value that is pretty close to the correct value.
Here are some examples(Serial monitor output):
Input is : 101
Numeric value is : 100
Input is : 110
Numeric value is : 111
Input is : 250
Numeric value is : 255
Input is : 210
Numeric value is : 211
You can test this in tinkercad here
Thank you
Dunno what is wrong with your code, try this:
bool isStringNumeric(String &str)
  uint16_t pos = 0;
  while (pos < str.length())
    if ((str[pos] < '0') || (str[pos] > '9')) return false;
    pos++;
  return true;
if (isStringNumeric(readString))
  int val = readString.toInt();
  if ((val >= 0) && (val <= 255))
    Serial.print("Input is : ");
    Serial.println(readString);
    Serial.print("Numeric value is : ");
    Serial.println(val);
Also mind that using the "String" data type on an AVR based Arduino may cause memory corruption which leads to all sorts of havoc.
The serial input basics tutorial shows robust ways to read serial data into strings (null terminated character arrays not to be confused with Strings) and parse the data.
Have you tried running your code on a real Arduino ?
Here are my results using your code on a Nano
Input is : 101
Numeric value is : 101
Input is : 110
Numeric value is : 110
Input is : 250
Numeric value is : 250
Input is : 210
Numeric value is : 210
It seems like the problem is with TinkerCad
TinkerCad doing something different ? That is nuts.
I tried the sketch in the Wokwi simulation, and it works just like the real board.
@newbie_e Could you show a full (short) sketch the next time ?. Now we have to log in at Tinkercad to see the sketch.
Using many String objects with a Arduino Uno might cause the heap to keep growing. We try to avoid the String class with a Arduino Uno.
Could you get used to a indent of 2 spaces instead of 4 in the source code ? Arduino uses default two spaces, and I learned to like it.
A 'myString[i]' is a element in a array of String objects. But you don't have an array of String objects, you have just one object. [EDIT] It is okay as Danois90 writes below
I have made a comparison between Tinkercad and Wokwi: Virtual Online Arduino and ESP32 Simulator - Wokwi Arduino Simulator features - #3 by Koepel
I will add the bug that you found, thank you.
No, the String class has element access through operators.
Oops, sorry, I will fix my previous post.
This is the minimal test sketch for Tinkercad, I don't know how it is possible, but a cast of a integer to a String object sometimes fails:
// Test this in Tinkercad with Arduino Uno
  Serial.println( "--------------------");
  String Q = "110";
  int value = Q.toInt();
  String R = (String) value;
  Serial.print( "Ojbect Q is of course 110 : ");
  Serial.println( Q);
  Serial.print( "The integer is of course 110 : ");
  Serial.println( value);
  Serial.print( "The cast to String makes it 111 : ");
  Serial.println( R);
void loop() {}
they know this for a long time...
see https://tinkercad.zendesk.com/hc/en-us/community/posts/115007237807-Circuits-Arduino-String-
Thank you all for your replies.
I did as @Danois90 suggested to avoid converting the integer to string and just used a separate Serial.println to print the value.
Thanks again for your help.
