I want to be able to get the A1, 3, B1, 5 separated from this. I tried using strtok to separate AAAA, A1:3, B1:5 & ZZZZ and I was successful. I am not able to separate A1:3 and the B1:5 part using the same strtok with the ':' delimiter. Any suggestions on how to proceed with this problem?
groundfungus:
This code works like you want, I think. Hard to say what you were doing wrong as you posted no code.
Thank you, groundfungus & @jurs! The code by @groundfungus certainly works for the problem at hand! I didn't know that I could give a list of delimiters to the strtok function. And, I tried splitting the string into tokens using the ; and then splitting the ones with the : into 2 by passing it into another function which was written just for that.
I want to find a certain string in that and act accordingly. How can I do that?
I realize that char *strings[10] are pointers to where the split strings are located. How can I use the values in the strings for something like the above?
Who's allocating the memory for the output token strings?
No extra memory is needed. strtok() destroys the original string, by putting NULLs in place of the tokens, returning pointers to the appropriate parts of the original memory.
Who de-allocates it?
Since nothing was allocated, nothing needs to be freed.
It would often be nice to be able to tokenize a string, like "AAAA;A1:3;B1:5;ZZZZ" and get the tokens "AAAA", "A1:3", "B1:5", and "ZZZZ", and then be able to tokenize the tokens that contain colons independently, but, alas, that is not possible without making copies of those tokens and parsing them separately.
It's also not possible to have strtok() tell you which delimiter that it found as the next delimiter.
So, you really need to know a lot about the string that you are trying to parse.
Thank you for the insight, @PaulS. I do know the specifics of what I am going to receive, so it is helpful. Like you said, if I didn't know about it, it would have a been a different problem to solve altogether!
