TomTom serial GPS mouse re-used for GPS-clock
Hello,
I am a newbie in programming, so for my first project I needed it to be hardware oriented as well.
The hardware part comes in, when I thought of using one of the old TomTom GPS-mouse's we had lying around.
I wanted to see if and how an Arduino could make use of the information provided by this mouse.
One thing lead to another, so yet another GPS-clock is born.
I found the TomTom GPS-mouse has 4 wires:
Red = +5V
Shield = Ground
Brown = RS232 out
Orange = RS232 in (not used by me)
One interesting thing I found was: the TomTom GPS uses 5V as power, but does OUTPUT the "real" RS-232 signals. It seems it has a voltage-converter build in.
Meaning, the signal moves between +12Vdc and -12Vdc. To overcome this I used a simple (often copied) TTL-to-RS232 Vice-Versa converter. I used just the half part that converts RS-232 to TTL. It needs inverting as well, the -12Vdc in RS-232 must be a 'high' in TTL, to be readable characters.
To go step-by-step I just used one of the several output-strings the TomTom GPS gives, the $GPRMC-string.
My code is build on bits and pieces I found on this forum and elsewhere, I do hope I did put all the credits in.
For learning myself the Arduino code, I needed lots of comments, so every time I read it, there was an explanation.
Some may think it is overdone, but it helped me.
Although the program now works, I may need some extra help in actually understanding this part of the code, and to see if my explanation makes sense:
// show_time_date()Begin============================================================
void show_time_date(void) {
// For me this is the cool part, because the variables come out as integers.
// So we can make calculations with them
// I use the indices-array to point at the separators in the buffer, the variables I want are found 1 or 2 postitions behind the separator.
// For the hours we get de 1 or the 2 in eg. 15h or 23h, so I multiply by 10. The normal hours are just added to the previous value. ((1x10)+5) or ((2x10)+3)
// Explanation:
// Every serially received Character comes in as a Byte, containing 8 bits
// Eg. a received number '9' has an ASCII value of '39', which is '0011 1001' this a '3' and a '9'
// The '&0x0F' (&0x 0000 1111) "masks" the use of the left (higher) 4 bits, (0011) which is the '3' part, so the right (lower) part '9' (1001) gets through.
// So  '&0xF0' (&0x 1111 0000) would allow for the '3' to get through.
// This (separated) '9' is than converted into an 'int' (integer) so we can use it in calculations.
// This is done with every individual number to get the full Time and Date.
// For the GPS-position we just use the Character 'A'(Active) or 'V'(Void).
     myday = (((int)buffer[(indices[8])+1]&0x0F)*10)+((int)buffer[(indices[8])+2]&0x0F);  // Since we know where the seperators are, we can can precisely identify the position of certain variables
   mymonth = (((int)buffer[(indices[8])+3]&0x0F)*10)+((int)buffer[(indices[8])+4]&0x0F);  // Since we know where the seperators are, we can can precisely identify the position of certain variables
    myyear = (((int)buffer[(indices[8])+5]&0x0F)*10)+((int)buffer[(indices[8])+6]&0x0F);  // Since we know where the seperators are, we can can precisely identify the position of certain variables
    myhour = (((int)buffer[(indices[0])+1]&0x0F)*10)+((int)buffer[(indices[0])+2]&0x0F);  // Since we know where the seperators are, we can can precisely identify the position of certain variables
  myminute = (((int)buffer[(indices[0])+3]&0x0F)*10)+((int)buffer[(indices[0])+4]&0x0F);  // Since we know where the seperators are, we can can precisely identify the position of certain variables
  mysecond = (((int)buffer[(indices[0])+5]&0x0F)*10)+((int)buffer[(indices[0])+6]&0x0F);  // Since we know where the seperators are, we can can precisely identify the position of certain variables
   GPS_position_fix_indicator = ((int)buffer[(indices[1])+1]);                            // Since we know where the seperators are, we can can precisely identify the position of certain variables
/* The syntax is often as follows, depending on the version of the NMEA firmware the GPS receiver is using internally:
// indices are pointing at:
   indexcounter = 0          1 2       3 4        5 6     7     8      9    10 12
            $GPRMC,225446.123,A,4916.45,N,12311.12,W,000.5,054.7,191194,020.3,E*68
Here is a link to the full code I put together :https://drive.google.com/file/d/0B0OBe102ekzocUhYOVJBbXpDWTg/edit?usp=sharing
Un saludo,
Satbeginner
I worked on my code a bit more, I changed the 'user interface' by using the 8x2 display differently.
I now just show the Time in HH:MM and the Date in DD-MM-YY
Behind de Time I show the following:
ZT when we have a GPS fix AND we are in DST
zt without GPS fix, but still in DST
WT when we have a GPS fix and DST is not active
wt without a GPS fix, and also DST is not active.
ZT stands for ZomerTijd (Dutch) and WT stands for WinterTijd (again Dutch)
Daylight Savings Time in Dutch is called Zomertijd.
I also changed the Back-light behaviour.
When first powered ON the back-light comes ON and stays ON till a valid Date and Time was found.
Then, when the button connected to pin2 is pressed a simple interrupt-routine switches the back-light ON for 5 seconds.
Also, the Back-light comes ON for 10 seconds every full hour, so at 13:00, 14:00 etc. like a silent chime of a bell.
Here is a link to the new version of the code: https://drive.google.com/file/d/0B0OBe102ekzodkZHN0xaSUJXUk0/edit?usp=sharing
Hello all,
here a complete overhaul of the code.
I found there were problems in the serial-readroutine, sometimes parts of the strings were missing, and there was a memory-leak in the routine that processed the buffer.
So I changed to using the SoftwareSerial port instead of the standard UART port.
I also made the main loop() just a series of subroutines.
These routines are only executed when the previous routine was successful.
This speeds-up things a lot.
There were a lot cosmetic fixes as well.
Here is the link to this new version: https://drive.google.com/file/d/0B0OBe102ekzobWFYZkozZWhoVjQ/edit?usp=sharing
Un saludo,
Satbeginner
