Hey im pretty new to arduino, I have this code and when I go to verify it, it reads 'Tone' does not name a type and highlights Tone tone1;, im not sure what that means or what to do about it, I have another tab with tone.h in it and ive downloaded the tone library to my desktop ( i heard to download it to the arduino file itself but im not sure how to do that.
Heres the code:
#include <Tone.h>
Tone tone1;
#define OCTAVE_OFFSET 0
int notes[] = { 0,
NOTE_C4, NOTE_CS4, NOTE_D4, NOTE_DS4, NOTE_E4, NOTE_F4, NOTE_FS4, NOTE_G4, NOTE_GS4, NOTE_A4, NOTE_AS4, NOTE_B4,
NOTE_C5, NOTE_CS5, NOTE_D5, NOTE_DS5, NOTE_E5, NOTE_F5, NOTE_FS5, NOTE_G5, NOTE_GS5, NOTE_A5, NOTE_AS5, NOTE_B5,
NOTE_C6, NOTE_CS6, NOTE_D6, NOTE_DS6, NOTE_E6, NOTE_F6, NOTE_FS6, NOTE_G6, NOTE_GS6, NOTE_A6, NOTE_AS6, NOTE_B6,
NOTE_C7, NOTE_CS7, NOTE_D7, NOTE_DS7, NOTE_E7, NOTE_F7, NOTE_FS7, NOTE_G7, NOTE_GS7, NOTE_A7, NOTE_AS7, NOTE_B7
char *song = "smb:d=4,o=5,b=100:16e6,16e6,32p,8e6,16c6,8e6,8g6,8p,8g,";
void setup(void)
tone1.begin(13);
#define isdigit(n) (n >= '0' && n <= '9')
void play_rtttl(char *p)
// Absolutely no error checking in here
byte default_dur = 4;
byte default_oct = 6;
int bpm = 63;
int num;
long wholenote;
long duration;
byte note;
byte scale;
// format: d=N,o=N,b=NNN:
// find the start (skip name, etc)
while(*p != ':') p++; // ignore name
p++; // skip ':'
// get default duration
if(*p == 'd')
p++; p++; // skip "d="
num = 0;
while(isdigit(*p))
num = (num * 10) + (*p++ - '0');
if(num > 0) default_dur = num;
p++; // skip comma
Serial.print("ddur: "); Serial.println(default_dur, 10);
// get default octave
if(*p == 'o')
p++; p++; // skip "o="
num = *p++ - '0';
if(num >= 3 && num <=7) default_oct = num;
p++; // skip comma
Serial.print("doct: "); Serial.println(default_oct, 10);
// get BPM
if(*p == 'b')
p++; p++; // skip "b="
num = 0;
while(isdigit(*p))
bpm = num;
p++; // skip colon
Serial.print("bpm: "); Serial.println(bpm, 10);
// BPM usually expresses the number of quarter notes per minute
wholenote = (60 * 1000L / bpm) * 4; // this is the time for whole note (in milliseconds)
Serial.print("wn: "); Serial.println(wholenote, 10);
// now begin note loop
while(*p)
// first, get note duration, if available
num = 0;
while(isdigit(*p))
if(num) duration = wholenote / num;
else duration = wholenote / default_dur; // we will need to check if we are a dotted note after
// now get the note
note = 0;
switch(*p)
case 'c':
note = 1;
case 'd':
note = 3;
case 'e':
note = 5;
case 'f':
note = 6;
case 'g':
note = 8;
case 'a':
note = 10;
case 'b':
note = 12;
case 'p':
default:
note = 0;
p++;
// now, get optional '#' sharp
if(*p == '#')
note++;
p++;
// now, get optional '.' dotted note
if(*p == '.')
duration += duration/2;
p++;
// now, get scale
if(isdigit(*p))
scale = *p - '0';
p++;
scale = default_oct;
scale += OCTAVE_OFFSET;
if(*p == ',')
p++; // skip comma for next note (or we may be at the end)
// now play the note
if(note)
Serial.print("Playing: ");
Serial.print(scale, 10); Serial.print(' ');
Serial.print(note, 10); Serial.print(" (");
Serial.print(notes[(scale - 4) * 12 + note], 10);
Serial.print(") ");
Serial.println(duration, 10);
tone1.play(notes[(scale - 4) * 12 + note]);
delay(duration);
tone1.stop();
Serial.print("Pausing: ");
delay(duration);
void loop(void)
//I chose pin 2 to read the PIR signal
if (digitalRead(2) == (LOW)){
play_rtttl(song);
delay(5000); // wait 50 seconds for me so it doesn't endlessly loop.
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
